5 Attachment(s)
The LCI retrofit is a retrofit cable set for the facelift lights. This is the BMW OEM solution to get the facelift headlights and taillights working on pre-LCI cars. A new light module (LM) needs to be installed on cars before 09/06.
Part numbers: E60: 61 12 0 432 110 E61: 61 12 0 432 397 The cable kit consists of many parts (adapters, sockets, etc.). A person would have to buy the facelift headlights, taillights and light module separately. The TIS document states an approximately 5.5 hours. But I would think it is much longer for older cars or when troubleshooting arise. It sounds like a 2 days labor extensive dealer job! For the taillights, couple of the wires from the cables need to be routed all the way to the front of the car--connecting the pins directly to the dismantled plug on the LM. The headlights require bumper removal. The pre-LCI existing plugs (the 8-pin plug and 4-pin plug) have to be completely disassembled. A provided 12-pin socket will then be individually wired and this plugs into the facelift headlight. And finally the car is program/encoded. Attachment 40055 Attachment 40056 Attachment 40057 Attachment 40058 Attachment 40059 |
Do you know how much for all the hardware and estimated labor costs for the install?
Rootkit, how much does it cost for the whole retrofit kit cables & LM? (excluding headlights & tail lights)...
The approx. price breakdown...
a. AHL-xenon headlights: 1,850 b. Taillights: 430 c. Light module: 350 d. Retrofit cable set: 50 e. "Labor": 1,000 Give or take, somewhere between $3.5k to $4k out the door. :o |
So Rear Tailight = $430 + $50 cable?
I think you will also need the light module :think: but I'm not sure. |
Yes, new light module if your car is older than 09/06. In addition to that, programming.
I thought the light module is only for LCI front headlights right? LCI Rear only needs a retrofit cable isnt it.
4-5k for lights... I think we all would agree that you can do a lot more with 4-5k, than just lights. =)
Get some 20 inch rims! or.. bodykit, and rims and springs. heh. So much. or just keep the car the same and get a motorcycle, Used of course. If you want speed that is. If is cool that BMW offer's the retrofit cables and such, but its just so expensive. MK |
