Hartge Wheels
#41
yes, $3400 shipped to my door, including set of wheel lug bolts & locks, by the way, they came in individual boxes not banded up like tire rack or discount tire.
#42
Guest
Posts: n/a
Originally Posted by Guest' date='Jan 20 2004, 03:12 PM
So I started researching n those wheels, The best prices I got delivered to my door (no sales tax) are :
37 31 0395 J
HARTGE wheel set
8.5 x 19" offset 15 with 245 / 35 ZR 19 front
9.5 x 19" offset 22 with 275 / 30 ZR 19 rear
with
C0ntis contac2 3240
Dunlops sp9000 3130
Pirelli Pzero assim 3262
Do you think these prices are it?
In addition, I hear the Contis contac2 are better than Pirelli Pzero? anyone here have any experiences
Thanks in advance guys
37 31 0395 J
HARTGE wheel set
with
C0ntis contac2 3240
Dunlops sp9000 3130
C0ntis contac2 $3240
#43
Originally Posted by cidair' date='Jan 19 2004, 01:59 PM
E60 versus E39 wheels.
The bolt pattern are the same but the center hole is smaller on the E60 ( 72.5 mm ) than on the E39 ( 74.1 mm ).
You easliy solve this with a distance ring ( to get the wheel accurately centered ) if you want to put E39 wheels on the E60.
Just watch the offset to be as close as possible to the OEM wheels.
Otherwise you will change the wheel geometry = bad handling!
First, thank you for the info.
What are the factory specs for offset for 545iA?
I haven't found this information anywhere.
#44
i would think that the offset would be the same as what i had previously posted, although it changes based on wheel size, i.e. 19" have a different offset for 20" but would mount the same on either a 530 or 545, the following infor from hartge:
37 31 0395 J (part number)
HARTGE wheel set
37 60 0430 J
HARTGE wheel set
9 x 20" offset 18 with 245 / 30 ZR 20 front
10 x 20" offset 22 with 285 / 25 ZR 20 rear
37 60 0420 J
HARTGE wheel set
10 x 20" offset 28 with 285 / 25 ZR 20 rear
HARTGE wheel set
37 60 0430 J
HARTGE wheel set
37 60 0420 J
HARTGE wheel set
madein
06-06-2015 11:48 AM
