Angel Eye Question
My Ride: 08 528xi Unknown options :/
Angel Eye Question
hey guys I'm new here, and I was wondering if there is an angel eye led upgrade for the e60 that is NOT an H8 bulb. I have an 08 528xi and it has projectors for the low beams and my AE do not take h8 bulbs, but a bulb with a brown casing around it. I've done research and found some, but they were old posts and the links brought me to pages that no longer exists. and if you dont mind, can you tell me what some of the packages and options that come on the e60s are, I'm not really sure what all I have
thanks.
thanks.
My Ride: BMW 530xiT (E61)
put your VIN number into this site and you should be able to access your build sheet:
bimmer.work : VIN Decoder for BMW
If you post it here, people might be able to help you figure out which option packages you have. it should be pretty straight forward based on the build sheet.
i used these for my halos. they are OEM and not an aftermarket LED upgrade but after searching for a while i couldnt find a good aftermarket solution that was both reasonably priced AND high-quality. I would welcome being proven wrong on this one because i'm not a huge fan of the yellowish look of the OEM halos.
mortaza_tollo
07-23-2015 02:47 AM
