Steering column won't move
My Ride: 2006 M5
Hello, I just got a 2006 M5 earlier this week, 87k miles, everything inside works perfectly except for the steering column adjustment and it's stuck fully up.
I took the under dashboard cover off and did some diagnosing. INPA shows that the little switch in the column is working, i see signals for all 4 directions. When I check the wiring at the motor though I'm not getting any volts at all.
I checked the fuses i could think of, 71 in trunk and 2 other fuses which power the central body module just in case. they're all fine.
I can't find any information on this issue anywhere and any help is greatly appreciated.
Thanks
Thanks
My Ride: 2006 M5
ah, thanks for the pointer,
As for the fault codes, i'm not even sure what to read them from, which module would have them. I checked the central body module and it doesn't even show any activations for a steering column, and no codes.
I'll post this on the m5board too and see if i get help there.
Thanks
Thanks
jeffandjaimie
07-08-2015 05:48 PM
