HIGH BEAMS!
Old 02-14-2011, 10:02 AM
healthservices's Avatar
Originally Posted by nomis_nehc
That's not entirely correct. The reason his reflectors melted is because he retrofitted, but it was incomplete. His high beam was operating at higher temperature of what it should be otherwise. Realistically, this shouldn't be an issue, otherwise BMW would have put it in the manual saying that you shouldn't have your high beams on for x amount of time, or have some kind of recall.
The reason BMW does not have to, is because the inner bulbs do not light up when the high beams are 'on' on xenon equipped cars right?
You can run the high beams (inner bulbs all day) on Halogen assemblies because the light and reflector are built differently. The inner bulbs light up on Halogen equipped cars.
Then again I maybe totally wrong as the OP has a LCI car and it maybe totally different on these cars.
Does the OP have a Halogen equipped car or Factory xenon?
Old 02-14-2011, 10:30 AM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
The LCI halogen headlights does have halogen reflectors even thought he low beam is projector. So in theoretical terms, the heat dissipating from the HID of 35w should still be lower than the 50-55w that a stock halogen bulb produces.
The inner bulb for the LCI xenons, I believe act as cornering lights, and since they're bi-xenon, there's no separate bulb from the low beam. Given what the OP has said so far, it sounds like he has LCI halogens.
Old 02-14-2011, 12:21 PM
I wonder if a simple jumper and a diode from the fogs to the inner lights (high beams) would do what the OP is asking for.
Then the OP would be constantly getting flashed by people being blinded
Old 02-14-2011, 01:16 PM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
In theory that should work, so when he turns on the fogs, his high beams will be on. Obviously the downside is that he can no longer turn off the high beams whenever his fogs are on.
Additionally, I am not sure what the long term effects might be drawing that amount of current from that circuit.
Old 02-14-2011, 03:06 PM
Or you could wire it the other way around, that way whenever the high beams are on the fogs are on. Then if you want just the fogs you can just turn on the switch to the fogs. This is of course if the inner lights go on when the high beams are on.
Old 02-14-2011, 03:30 PM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Lol, true. It's too much work in my mind. Much easier to just code the damn thing. Cleaner and faster.
Old 02-14-2011, 04:25 PM
yeah if you have a device to code with!
Maybe later this year if I'm too bored and have some extra cash. Otherwise I'd just have you come over.
Old 02-16-2011, 05:21 AM
np0218's Avatar
Can someone tell me step by step how to do it? I don't feel like paying 150 for it lol
sxybeemr
06-20-2023 10:13 AM
Vman33
03-14-2022 04:43 AM
Jiawei Zhao
10-21-2015 08:46 PM
lcc014
DIY: Do It Yourself
09-10-2015 05:57 AM
spediegunz
08-30-2015 09:43 AM
Quick Reply: HIGH BEAMS!
