Gear settings
My Ride: 2007 M5, Indi red, Silverstone interior
God its good to be back!!!
Gone:
2008 X6, Black, Black Nappa,
2007 M5, Black, Full Black Leather, TV's & Playstation's in headrests.
Gone: 2001 M5, Black on Black
Probably a silly question as i can not see it in the manual but is it possible to set the gear response higher than the 1 bar it is set at when you start the engine? Or is the only way by manually changing every time you start the car.
I am hardly ever in anything less than S4 for this reason. I did think I saw somewhere where the older model year default to S1 or D1. Maybe a change for 2008.
To answer your question, NO. It always goes back to default after you turn off the car. Just pretend you are a pilot doing his pre-flight checklist as you change all the settings each time, HaHa!
My Ride: 2005 530i upgraded to 2007 550i 12/20/06
Took delivery of 2008 M5 3/25/08 cf delete K&N filters, the rest stock.
I'm with Glock-357. Mine defaults to either s3 or d3 if you switch it to D mode. S4 is my normal mode. D4 for the highway driving at the present time.
I am at 530 miles to go for the break in. Hope this helps.
Gone:
So do you think the 2007 M5 has a default setting of D1? and that this has changed for 08? (If so maybe time to trade in) Its not to much of a problem but a bit of a pain when stopping and starting a lot. Also are the American models ahead of the UK? As when i purchased mine new in July 07, this forum were talking about there 08 cars?
Check with the guys on m5board.com, there are many 2007 M5's there and I think a few from the UK. What does the manual say about this?
My Ride: 2008 E60 M5/SMG (LCI)
Interlagos Blue/Black Merino
Aux input, sun protection glass, Bluetooth, Voice control
mine's a 2008 model and also defaults D1. but when i slip it into manual, it's remembered my last setting (S5).
I read in the manual that the car will always start in D1 as a default.
Gone:
Awest91
09-17-2022 11:05 PM
pcy
09-12-2021 06:55 PM
chadillac2000
42
09-13-2017 11:15 AM
AdPock
E39 Discussion
04-10-2015 01:06 PM
