Euro LC question
My Ride: 2008 E60 M5/SMG (LCI)
Interlagos Blue/Black Merino
Aux input, sun protection glass, Bluetooth, Voice control
Guys,
When using LC, will the car auto shift? i seem to read everywhere that it does.
I've tried LC successfully, but only went through the 1st gear.
(I'm in UK)
(I'm in UK)
If you guys are interesting Singh Autosport can install European LC.
http://singhautosport.blogspot.com/2008/11...ch-control.html
Yeah it does auto shift. BUT depending on traction it will likely bounce off the limiter a few times before it does shift up..... Did this myself a few times thinking hey it doesn't autoshift up and lift off to stop the engine screaming! But just keep ya foot planted and it WILL autoshift up Warm tyres and decent traction with some heat on the road and in tyres will make a difference, have faith it will work
Another tip is do NOT have suspension set to hard, leave it on soft setting and it will take off a LOT better. With max suspension it bounces a lot more, with soft it allows the rear end to "bog" down a little more and get better traction. I actually find for everday use, standard "M" button setting in S6 is just as effective as a launch anyway.
Originally Posted by EuroCarFan' post='822041' date='Mar 20 2009, 10:19 AM
I believe the Euro LC autoshifts while the US doesn't.
"have faith", it's the way to go. once warmer weather here again, i will get on it.
good point about EDC setting.. makes sense to let the rear bog down.
aqualibrium
07-21-2015 03:11 AM
