DSC Malfunction
My Ride: '06 M5 Silver/Grey BLK, HUD, SMG, fully Loaded...RPI Scoops Red, Block Off Plates, BMC Filters. Hyper Silver Painted Wheels, RPI Full GTS Exhaust
Hi All,
Just got my M5 back from the dealer, what a joke. Now after 15 min or so driving I get a DSC malfunction error then right after a tire pressure sensor not available error. Seems pretty common, anyone have this issue, and any way to fix outside of the dealer? I can bet its a bad sensor, but not sure where the DSC would be located.
My Ride: 04 530i
06 ///M5
you probably have a bad tire sensor and thats causing the car to throw a DSC error. The DSC cannont function correctly without inputs from the tire sensors atleast that is where I would start because tire sensors are cheap (located in the tire on the valve stem usually).
