Hi All,
Just got my M5 back from the dealer, what a joke. Now after 15 min or so driving I get a DSC malfunction error then right after a tire pressure sensor not available error. Seems pretty common, anyone have this issue, and any way to fix outside of the dealer? I can bet its a bad sensor, but not sure where the DSC would be located. |
you probably have a bad tire sensor and thats causing the car to throw a DSC error. The DSC cannont function correctly without inputs from the tire sensors atleast that is where I would start because tire sensors are cheap (located in the tire on the valve stem usually).
