I tried searching but was unsuccessful. 2008 528xi
I just installed bilstein b6 shox/ struts and H&R lowering springs but now xenons seem aimed too low. Is there any way to adjust this? Thanks in advance, Mark |
My quick search :think: http://forums.5serie...1&#entry1106496
Just wonderin' what is the Bilstein part number you are using? And how's the ride paired up of H&R springs + B6? Pics of the ride and/or detail pics of the suspension? |
Thanks, I searched xenon instead of HID and didn't come up with anything.
Ride is a little more firm than "I" sport. Not lowrider bad at all. No problems scraping or bottoming out like seemed to be the case with the factory shox/struts and H&R xi springs. It bottoms out on what it would have bottomed out on before the change. Sorry no pics. I did the switch with a friend and it is a PITA - took 6.5 hrs but I had never done this before and he had done AWD VW's but never a BMW. I used the B6 bilsteins (not the B8 sports - they are not yet available in the US) You can get them thru ajusa.com or shox.com |
2 Attachment(s)
The headlight aim adjustment screws are the white plastic allen head sockets on the top of the headlight unit - as shown in the picture from the previous post. You'll need to set up the "target" on a wall 33 feet from the front of the car on a level surface. I used my garage door after sun set - the pattern is very obvious in low light.
