WSTO - Wheel Weight Comparisson
#21
Originally Posted by mhs525' post='1022615' date='Oct 1 2009, 08:44 PM
Yes... and the right set up can take a lot more than 4lbs off. Although BMW offers a few light weight forged wheels most are cast and can weigh up to 30 pounds for an 18" wheel. If you replace a 30 pound wheel with a forged 20 pound wheel that's 10 pounds a corner, 40 pounds for four, and a 33% reduction in unsprung weight. Changing from heavy run flats to normal tires saves even more weight. It really makes a difference. After experiencing the effect first hand I will never replace OEM wheels again without reducing weight.
If someone could post the weights of common bmw wheels that would also he very helpful.
weights of the: 138's, 123's, 124's, 166's, 167's, 172's, and 128's would be nice because i think these are the most common wheels used on the e60.
#22
My Ride: E60 M5, F85 X5M
Originally Posted by DRANGED' post='1022653' date='Oct 1 2009, 07:51 PM
Since different wheel offsets can cause substantial variances in weights within the same model wheel, are these weights for E60 specific fitment? If not, are all the wheels being compared of the exact same fitment and offset?
You are right that actual weights depend on applications but this is a good rough guideline.
#24
Originally Posted by v_therussian' post='1022851' date='Oct 2 2009, 02:01 AM
How are the alloy tech rims? Reliable? Bend/crack resistance decent?
#26
Originally Posted by EuroCarFan' post='1022953' date='Oct 2 2009, 09:10 AM
I'm not sure how 10,000 ton rotary forged wheels compare to wheels made on an 8000 ton press but if they're the same reference, the higher the pressure, the stronger the wheels. Most forged wheels are done on 5000-6000 ton presses and only some are made on 8000 ton presses like wheels from Champion Motorsport, Radenergie and Neez. Those are among the strongest wheels out there and that is why they're also pricy. I assume these Alloy Tech wheels are stronger since they're made on a 10,000 ton press but hopefully WSTO can confirm.
BTW its probably safe to assume it, but how expensive are Alloy Technic rims?
#27
The wheels weighed are a various assortment of fitments though.
#29
This is a great Thread.
Any more weights?
I really like the Alloy Tech wheels!
I will probably buy these of somebody in the future for a summer set.
Has anyone ran a staggered set on an M5 with good handling results i.e. 19x9 in the front and 20x10.5 in the rear. Or would this setup mess up the handling dynamics. I believe it would look quite mean!
Any more weights?
#30
My Ride: 2004 SMG 545i
silver grey metallic / bamboo anthracite / black leather
CPO
sport package
premium sound
park distance control
cold weather package
do you have any VMR V710's in the 19" height weighed? or possibly even a Forgestar F14 in a 19"??
