Worried I am making an Error in Purchasing Springs
wait for Tirerack to get the H&R sports springs and koni to be available. I had 166s with stock suspension and the ride was like stock. I would switch out to aftermarket shocks after 35000 miles.
I would show you a pic but photbucket is down
I would recommend you wait for the sports or go with eibach or dinan instead. the expensive part of suspension work isn't the springs, it's the labor, and you don't want to have to do it several times. BTDT- I went through three suspensions on my E36 before I was happy.
My Ride: 2004 525i Jet Black on Grey Interior---
Tint: Sides 20% Rear Windshield 5% Front Windshield 35%
Wheels: Zenetti Five's 20" by 8.5(front) 20" by 10(rear)--
Tires: Pirelli Asimmetrico 245/35/20(front) 285/30/20(rear)--
Body: Hamann Full Front Spoiler, Rieger Side Skirts, Rieger Rear Apron, AC Schnitzer Trunk Wing
Interior: AC Schnitzer Pedal Set and E-Break
Springs: H&R Sport Springs--
Audio: 2 12" Kicker L7's with a Rockford Fosgate 1501bd Amp With Custom Trunk Enclosure
SOON TO COME:
-M5 Mirrors
-M5 Trunk Finsher
-Brembo GT Big Brake Kit
-Hamann 6 Series Front Spliter Molded
-Hamann Roof Wing
-Full Custom Sound System with TV's
The Koni shock will be no prob with the H&R race springs.. also I think if you keep your 19" 166's you shouldn't have to roll the fenders. If you had 20's I'd be more concerned but with 19"s you should be ok
My Ride: 2004 530i
premium package/active steering/auto sunshade/tiag/black dakota leather/logic 7
35% tint all around
19' DPE GT7
I've heard that the knoi sports pair well with the H&R sport springs.
My Ride: 2006 550i Black Sapphire/ Black leather, NAV, Sports Pkg, Active Steering, Shadow Trim, PDC, Heated Seats/Wheel, Logic 7 Sound, 6 Disc Changer, Blue Tooth, Comfort Access/Seats, ACS Aluminum Pedals, Bi-Xenon lamps and MTEC 2X Super White Foglights
kind of a side-bar, but it's just funny to me how I bought 167's (19's with M6 offset) and I can't run with the 285/35 tires on them because they are too big a diameter and will rub apparently...... but they when people put the correct tire size on (275/30) the first then becomes, how do I drop it?
just seems like I could have removed 3/4 of an inch and saved a ton of money by just using the stock M6 tires.
My Ride: 2004 530i
35% tint all around
19' DPE GT7
My Ride: 2004 530i
35% tint all around
19' DPE GT7
Originally Posted by 525iEnjoy' post='650714' date='Aug 20 2008, 09:19 AM
When running a 285/35 run a 32mm off set in the rear, Its close butt it works!
yes. but if you want 12 inches of tread you need to run a non agressive offset. Ofcourse you could have the fenders flared and have the best of both worlds!
Here is a pic from mine before, look how close the fender lip is to the tire..just about a fingers worth up and down the maybe 2mm side to side (tire tread to edge of fender)
