Worried I am making an Error in Purchasing Springs
My fenders are not rolled, non-sport package, not currently lowered, tire size and wheel type seen in my sig (m6 offset). I have a set of Koni Sport shocks/struts I'm going to install and I ordered the H&R Race springs BECAUSE the Sport springs are on 5-6 week national backorder at modbargains.com. Will I have rubbing and will it look really slammed? I don't want a "low-rider" look. I don't want it to look ghetto, gangster, or otherwise. I just want it to look sporty and sharp. I'm having this lowered next Monday.
Please note I'm not looking for opinions on what other types of springs I should get, coilovers, or otherwise. I just want to know from an experienced person whether or not I'm going to be rubbing after these items are installed and whether or not I should be against putting race springs on from H&R vs the sport. Thanks guys.
My Ride: 2007 E60 530i
Color: Jet Black/Black Anthracite
STEP | Sport | Premium | NAV | Logic 7
EXTERIOR:
M-Tech Kit | M5 Mirrors, Trunk Finisher | Jet Black Kidney Surrounds | Madico Charcool Tint 54%, 35%
LIGHTING:
Euro-Headlights | Euro-LCI Tail Lights | AiB V3.0 | Solaris Invisi-bulbs | OEM LED Plate Lights
PERFORMANCE:
Porterfield R4-S Brake Pads | K&N Air Filter
WHEELS & SUSPENSION:
Work VS-XX 20x9, 20x10 | Toyo T1R 245/30/20, Michelin Pilot Sport A/S 295/25/20 | KW V2 Coilovers | Rogue Engineering 15mm Spacers
Race springs sit pretty low, if you have the money get yourself a set of KW V2's.
That is toally Greek to me. I have no idea what KW V2 means or how that will be better than what I am getting considering I'm getting H&R plus a Koni kit. I'm not using stock shocks/struts
Originally Posted by Howitzer' post='650326' date='Aug 19 2008, 08:41 PM
That is toally Greek to me. I have no idea what KW V2 means or how that will be better than what I am getting.
KW V2 are coil over shocks and springs in which the ride height and dampening characteristics can be adjusted. They can be best described as feeling much like the OEM factory sport suspension with greater dampening adjustment options and adjustable ride height.
http://www.kw-suspension.com/en/30_Product...overs/index.php
Originally Posted by DRANGED' post='650334' date='Aug 19 2008, 08:47 PM
I think you will regret H&R race springs with factory suspension. It will be very stiff, ride like a tank and the factory shocks will not be able to handle the rebound of the race springs.
Like I said, its actually going to be on Koni sport shocks/springs, not stock suspension. With that being said, would the race springs be ok with that?
These:
EXTERIOR:
LIGHTING:
PERFORMANCE:
Yeah you will be fine with some Koni's, but the drop might be too low for you.
Your tires look somewhat tucked into the fender. Do you have just a sport package or anything else? EDIT: Nevermind I see you're using coilovers.
These:
These:
