Wiring help needed - Cooling Fan Upgrade (400W Fan-3 wires with 600W fan-4 Wires.
Old Nov 14, 2019 | 02:42 AM
Pete7811's Avatar
My Ride: E60 (LCI) M sport, Lane departure, Bluetooth, Xenons.
Engine: M57
Post Wiring help needed - Cooling Fan Upgrade (400W Fan-3 wires with 600W fan-4 Wires.
Hello I am towing a heavy twin axle caravan to subtropical country soon so I decided to upgrade the cooling system of my E60. The tow bar was coded and is working fine I am curious if I need to do any more coding for the 600W fan to work, but the main issue I have is that the purchased fan (600W) has 4 wires (plus minus than red and yellow) and mine has only 3 (plus minus and signal - yellow with red stripe). The 4 wire plug is surprisingly cheap from BMW, but I have no idea where to run the wire to. Can anyone point me to the right direction? BMW stealer-ship is not helpful much just want me to drop the cat there and charge me £170 for running a wire and another £120 for coding that may not even be necessary. Anyone here with some expertise who can shine some light on it?
Old Dec 3, 2019 | 06:41 PM
JuniorB's Avatar
Your fan is computer controlled,so running a higher watt fan is useless. This fan has power, ground, and a pwm signal from the ecu that, gives all control to the fan when ever it needs it. If you plan on towing, transmission, and oil coolers will reduce the engines temperature.
Empireauto
Jan 18, 2017 05:38 AM
mwaku
DIY: Do It Yourself
Oct 12, 2014 12:42 PM
BlackBear
Apr 15, 2011 10:39 AM
famed02
DIY: Do It Yourself
Apr 18, 2010 05:19 PM
jaireco
Jun 30, 2009 05:55 AM
