Will these headlights fit my car?
My Ride: 2005 525i
Will these headlights fit my 2005 525i that came with halogens?
https://www.umnitza.com/browse-by-ca...and-xenon.html
My Ride: 2005 525i
My Ride: 06 550i
Model Year: 06
Reflector headlights are the old style of lights that reflect light on to the road and you can see the bulb. Projector headlights usually have a lens, "project" light into the road and you cannot see the bulb. Lastly if you are still confused to a Google image search for e60 pre-lci halogen headlights
My Ride: 2005 525i
Thanks everyone! My last question is under the product description below where it lists what you get from the order it says MAY REQUIRE REWIRING OF ORIGINAL PINS.. If I order these will I have to rewire anything or do any compicated work or is it just plug and play?
My Ride: E60
Model Year: 2010
You shouldn't have to rewire if you never done any other modifications on your head light's wiring. It is direct plug in. Wiring may only be needed if you use any of the add-ons such as HID kits. You can always contact Umnitza as well.
The headlights come with an adapter for both preLCI and LCI.
If you have Xenon, they will require some work, but if you don't, it will plug and play.
My Ride: 2005 520i Sport Auto
I'm also interested in this headlight for my 2005 520i sport. If I decide to go for the upgraded Orion V4 option will it require rewiring? I may upgrade the LCM also a couple months later would that require any addition work to headlight wiring?
