Will The Following Wheels & Tires Specs Fit Standard E60s?
8.5" x 20" Offset 38
10" x 20" Offset 19
The bolt pattern is 5 x 120
Front tires 245/35/20
Rear tires 275/30/20
Thank you in advance
10" x 20" Offset 19
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
20mm spacers for the front. Back dimensions are identical to your previous R10. I don't think it's gonna work, Van, at least for the front.
Thanks for the quick reply and confirmation Joe Just curious, is it the offset of the front wheels that's what throwing it off?
38mm pushes the wheel too far inside. For a 8.5" wheel look for around 12 - 20mm offset. Avoid any offset 25mm or bigger.
Very cool, thanks again bro
OMG! SHAAADAAAAP Dan!!!
Originally Posted by Torquey5' post='502635' date='Dec 4 2007, 02:04 PM
+1
My Ride: 2007 E60 530i
Color: Jet Black/Black Anthracite
STEP | Sport | Premium | NAV | Logic 7
EXTERIOR:
M-Tech Kit | M5 Mirrors, Trunk Finisher | Jet Black Kidney Surrounds | Madico Charcool Tint 54%, 35%
LIGHTING:
Euro-Headlights | Euro-LCI Tail Lights | AiB V3.0 | Solaris Invisi-bulbs | OEM LED Plate Lights
PERFORMANCE:
Porterfield R4-S Brake Pads | K&N Air Filter
WHEELS & SUSPENSION:
Work VS-XX 20x9, 20x10 | Toyo T1R 245/30/20, Michelin Pilot Sport A/S 295/25/20 | KW V2 Coilovers | Rogue Engineering 15mm Spacers
Hey freed0m, these are the offsets for my wheels:
20 X 9.0 +25A
20 X 10.0 +19O
Before when I made real sharp turns, the inside of wheel would slightly rub up against the coilover. I used a 15mm spacer on the front to push it out flush with my rear because it sat in a little too far and as a result, no more rubbing. You'll probably need a more aggressive offset anyways to clear your BBK's.
I tried a 10mm spacer on the rear, but had severe rubbing issues. I think it could come out maybe another 5mm, but I just left it because as of right now, I have absolutely no rubbing in the back. I'm considering running 255/30 and 295/25 on my next set of tires.
Good luck with your wheel shopping. Get the BBS LM Champion Editions!
20 X 9.0 +25A
20 X 10.0 +19O
Hey KnIgHt, thanks for the input... I'm serioiusly considering BBS LM champ edition but man... 8-10 weeks wait is painful
