Widebody/flared fenders/rolled fenders Q
Old 09-08-2009, 10:37 PM
v_therussian's Avatar
I've got a bit of a crazy idea - bear with me on this one. I've got an Xi e60 and I've been looking at different rims for a long while now. X5 rims seem to be one of the best fits for these cars, but the set I'm looking at is 9.5 and 10.5 inches wide front and back, respectively. Offsets are 45 and 30 front and back, respectively.
I know that the rears would probably fit with just a little fender roll, given that there is A LOT of space there, but the fronts with 9.5 inches of girth will rub. Provided I get slightly narrower tires to get that "stretched on" look, how much can I really roll the fenders? Is there a way to flare the fenders without cutting/welding/additional kit and so - just to take the stock fenders and roll them about an inch on each side?
Old 09-08-2009, 10:40 PM
acuteperformance's Avatar
My Ride: 14 550i
Well you can roll the fenders and pull them but for a 5 series I wouldnt do the pulling part because it just looks tacky.
Michael
Old 09-08-2009, 10:42 PM
if you really need the extra room, why not get M5 fenders?
Old 09-08-2009, 10:46 PM
I don't want my car to be an M5 wannabe. Plus, the rears would still have to be rolled/pulled. AND it'd prolly be cheaper in my case to roll/pull the stocks...
Old 09-08-2009, 10:49 PM
just dont put the M5 badge on. those who have had M5 fenderes that I know of have put on different stickers on the fender grills, like Hamann or AC Schnitzer according to what mods they had on their cars.
Old 09-08-2009, 10:50 PM
that still leaves the question of rear fenders unanswered though. And if I'm gonna pull/roll the back ones, I might as well pull/roll the fronts - it would be cheaper and look less tacky than getting M5 fenders IMHO
Old 09-08-2009, 10:53 PM
My Ride: 14 550i
pulled fender
Old 09-08-2009, 10:57 PM
Originally Posted by acuteperformance' post='1002461' date='Sep 9 2009, 02:53 AM
pulled fender
Thanks Michael.
To your knowledge, is it possible to pull fenders more than that? I think for 9.5in fronts with 45 offsets to fit an Xi, I'll need to pull at least an inch on each side. The rears I'm not too worried about - they'll probably need to be rolled just a bit - mostly for the looks...
Old 09-08-2009, 11:00 PM
My Ride: 14 550i
9.5" in the front are you sure? that's pretty aggressive. normally the fronts are 8.5 - 9". i'll ask my buddy who pulls and rolls but 1" is a lot imho.
update: okay my buddy said you can probably get 1" but he doesn't recommend since it'll most likely turn out wavy. once you get to about 10mm it starts getting a lil wavy because of the spot welds.
Originally Posted by v_therussian' post='1002464' date='Sep 8 2009, 11:57 PM
Thanks Michael.
Old 09-08-2009, 11:16 PM
Thanks a million, Michael!!! This is exactly the info I was looking for. Yes, these are 9.5 fronts (they are for X5, so they are bigger than your average e60 setup) and 10.5 rears.
All said and done, 9.5 fronts with some "stretched on" tires will probably work, because the stock setup is ET43 offsets and 8 inches wide rims, but it has some serious room on the outside (maybe 20-25mm? anyone know for sure? ). So a 1.5 inch (~38mm) wider rim with a 2mm "deeper" offset would mean that these would "stick out" ~36mm (about an inch and a half) more than the stocks. But the <10mm fender pull/roll should clear the wheel. The question, then, is whether there is ~25mm on the outside in the stock setup...
At least, such is my hypothesis - can someone confirm/deny, please?
Now a question about the hub-bore: these rims have a 72.6mm hub-bore, which (I think) matches the Xi e60 without any hub-centric rings, or am I wrong in my assumption?
Quick Reply: Widebody/flared fenders/rolled fenders Q
