Who is running 9.5 square set wheels?
A little more info like which E60 do you have would help.
You would have to do some measuring to see if possible. Most likely it won't since a 9.5" wheel up front is a pretty wide wheel for a non-M E60. I currently run a 9" wheel up front and it barely fits.
What size are you running in the rear? Are you running staggered? Or square?
You think if I switch to RWD Front Brakes it would Fit then?
Thanks!
Thanks!
My Ride: 530Xi
B0xdesign
My ride is 530Xi with KWv3 suspension
Front: 19x8.5 Et35 245/35/19 fit just right
Rear: 19x9.5 Et33 275/30/19 were rubbing a bit, then I have the rear fenders rolled, now all good
My Ride: '09 535xi M Sport
it should work. you just have to get higher offsets and not lower too much or run stretched tires to prevent rubbing.
heres a guy with 19x9 et24 up front and it looks fine
OP your brakes have no bearing on fitment. It's best to run a 9" square setup or do a staggered setup which is possible on a XI. You just need to make sure both wheels are the same overall height, iirc within a 3% range. Of course closer the better.
chadillac2000
42
09-13-2017 11:15 AM
S4CH
05-04-2015 09:37 AM
