Who is running 9.5 square set wheels?
How hard is it to make these work for the fronts? What offsets? Thanks!
I think 9.5 et10 would work. At least in my M5 9.5x20 et10 is pretty much tucked in so I believe it would work with standard fenders as well.
- Antti - |
A little more info like which E60 do you have would help.
08 535xi. Thanks! Forgot to mention that!
In that case it wouldn't work what I said.
You would have to do some measuring to see if possible. Most likely it won't since a 9.5" wheel up front is a pretty wide wheel for a non-M E60. I currently run a 9" wheel up front and it barely fits.
What size are you running in the rear? Are you running staggered? Or square?
You think if I switch to RWD Front Brakes it would Fit then? Thanks!
Originally Posted by Booyaazaa
(Post 1550269)
1 Attachment(s)
B0xdesign
My ride is 530Xi with KWv3 suspension Front: 19x8.5 Et35 245/35/19 fit just right Rear: 19x9.5 Et33 275/30/19 were rubbing a bit, then I have the rear fenders rolled, now all good |
it should work. you just have to get higher offsets and not lower too much or run stretched tires to prevent rubbing.
heres a guy with 19x9 et24 up front and it looks fine http://cimages4.carsforsale.com/4023...C9956F44_1.jpg https://5series.net/forums/attachmen...-tires-148-jpg |
Originally Posted by rmayrap
(Post 1550584)
heres a guy with 19x9 et24 up front and it looks fine http://cimages4.carsforsale.com/4023...C9956F44_1.jpg https://5series.net/forums/attachmen...-tires-148-jpg OP your brakes have no bearing on fitment. It's best to run a 9" square setup or do a staggered setup which is possible on a XI. You just need to make sure both wheels are the same overall height, iirc within a 3% range. Of course closer the better. |
