Are Wheel spacers a safety compromise?
Old Jul 24, 2011 | 12:22 PM
Gene's Avatar
running 12.5mm Turner Motorsport (TMS) spacers all around since I picked up my m3 (about 4 months now). No vibrations or noise or problems. I like the design of the TMS spacers as they have small notches around the edge where you can insert a flat head screw driver or pry tool if/when you need/want to remove the spacers. Other brands do not have this, leaving you solely to rely on anti seize (need to apply during installation) and/or some serious elbow grease.
Old Jul 24, 2011 | 12:45 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
the main thing is, you have to use longer wheel bolts with spacers. other than that, they are pretty safe and reliable.
Old Jul 24, 2011 | 01:03 PM
Gene's Avatar
also need to clean all contact surfaces thoroughly before installing the spacers. Any slight misalignment could cause vibration later on..
Old Jul 24, 2011 | 02:41 PM
JOHN's Avatar
My Ride: 04 525i sport, premium, winter, xenon. xm satellite radio, navwithtv dvd system, 1 jl 10w7 sub powered by xtant 1001x amp. 20x8.5/10 on nitto nt555 rubber. acs roof and decklid spoiler, breyton front spoiler.
Originally Posted by IndyRedBeast
Turner Motorsport spacers are the best.
This and I've had them on at 200mph with no vibration
Old Jul 24, 2011 | 09:08 PM
G530's Avatar
NICE. Thanks for all the tips!
Old Jul 25, 2011 | 12:04 AM
tprenaldo's Avatar
My Ride: Mach5 05' 530i Black Sapphire Metallic w/Auburn Leather Seats, Heated Front/Rear Seats, Cold Weather Pkg, Premium Pkg, Sports Pkg, Xenon Headlights, NAV, Mud Flaps, 20" 166 Style Rims
Model Year: 2005
Engine: N54
The only thing with the longer wheel bolts is that I don't know if you can get wheel locks with the longer wheel bolts! Does anyone know
Old Jul 25, 2011 | 01:04 AM
JOHN's Avatar
No standard wheel locks will not fit on BMW. Someone may make long bolt locks, but ice personally never seen them before.
Old Jul 25, 2011 | 11:30 AM
JerimiahLee's Avatar
The spacers increase the offset correct?
I have an xi and I could essentially buy a pair with a lower offset and use the spacers to correct them to a more proper stance.
Old Jul 26, 2011 | 12:21 PM
Anzafin's Avatar
My Ride: Bmw 530d 2004
That's negative.
The spacers decrease the offset.
For example, if you have a 9" wide wheel with an offset of 20mm (ET20), and you install it with a 15mm spacer, the total offset will be 5 (ET5). The spacer pushes the wheel more out from the wheel well.
The smaller the offset (ET number), the more wheel is pushed out.
- Antti -
Old Jul 26, 2011 | 01:29 PM
G530's Avatar
Originally Posted by Anzafin
That's negative.
- Antti -
+1. Perfect, thanks!
