whats the best engine oil to use
i hope its ok to ask you guys ( i did tried searching) but first is i cant remember which one i use last time when i got the idrive msg "engine oil in in minimum level" now i just want to make sure i'll be getting the correct match for my car, ive read that the brand castrol is the best to use so is the castrol syntec 0W30 ok on my car??? thanks in advance, sorry for maybe a bit lazy and did not search further thanks again!!!
I tried "Q" High Performance oil this time around, but I didn't see a huge improvement in gas mileage or engine idle. I think Castrol Syntec or Mobile One Synthetic may be some of the better performing oils.
so the castrol syntec 0W30 is ok correct?? thanks man!!!!
My Ride: I have an 05 545i. It's a manual with a few options. This is my first BMW but I don't know how I'll ever be able to switch to something else.
It has to meet certain criteria, look on the back of the bottle for:
1) ACEA A3 certification
2) BMW LL-01 certified
And obviously be synthethic. I used Mobil 1 ow-30 (IIRC, myabe -40)
But just because the weights are the same doesn't mean it has those certifications, so double check for them.
many thanks again guys!! gotta love the E60 family here!!!
Location: Calgary, AB - Canada / Buenos Aires - Argentina
My Ride: 2006 BMW M5
Originally Posted by tiangco.a' post='987240' date='Aug 24 2009, 11:48 AM
i use lubro moly 5w40
Great oil, but pretty expensive.
Ive also been told to try 5w60
yes, I use 10w60 on my 545i that is an M oil and works perfectly on non-m cars. I am using it for 1 year and zero problem. the car runs very smooth and that oil is very helpful for high rpms.
