What Spacer to use in the rear
Firstly, I apologize if I'm duplicating previous posts, but I couldn't find an answer to my specific question, which is this:
I want to bring my rear wheels out slightly, to tip the handling balance a little more toward oversteer and have the rear wheels closer to the (more "flush" with) wheel wells. What size spacers should I use on my '06 530Xi Sport pk with 123 wheels? I would like to make sure that I avoid any rubbing and so on.
Conversely, are there any reliability/wear issues I should worry about when installing spacers?
My Ride: 2009 535xi Platinum Gray. M sport, Premium, Cold, Logic, PDC, Sirius, and Bamboo.
I've got a 10mm spacer on my rears at the moment and it only barely makes at dent. I will likely to a total of 20mm extended out over stock by using a wider wheel with a lower offset and spacers.
C's bimmer had his rear wheels extended out almost 30mm over stock without problems
Personally, I wouldn't risk anything wider than 15mm, though.
My Ride: 2004 545i TITANIUM GREY II on Black Dakota Lthr, Comfort Seats, Sports PKG, Premium PKG, Active/Dynamic Drive, NAV, Winter Package.
Do any of you guys experience vibration with the spacer? I want to use 15 mm H&R spacer for the back with the 128 Wheels 275/30/19 but the dealer tells me I might experience vibration. Is this true? I typically don't believe the STEALERS with anything. Also if I use 15 mm, would I experience any rubbing if I have 3 passengers in the back?
You recommendations please!
Originally Posted by ENstig8or' post='808503' date='Mar 5 2009, 04:35 PM
I just looked at some of the PM's Calton sent me when I was shopping for wheels. He did 10mm spacers in the front and 12 in the rear.
It's harder to know about the rears, but I am ok with the 10mm I now have on the rear of my 550i.
Originally Posted by DrLev99' post='808521' date='Mar 5 2009, 04:45 PM
I got vibration in the steering wheel with my M5 with 12mm spacers in the front...had to remove them.
Originally Posted by luigi524td' post='808657' date='Mar 5 2009, 07:44 PM
Were they hub-centric spacers?
Ok, people, tally: vibration or no?!?!
Keep in mind, I have an Xi, so rears are 8.5 inch rims w. 245's. I'm thinking to go 15 or 20 mm (more likely 15mm).
