What do larger wheels implicate?
First aspect to consider is weight. However, almost before you delve into it, a disclaimer should be made that some 19's are probably a lot lighter than your stock 17s (especially, if you'll be going from RFT to non-RFT in the process). But weight is the most important aspect as it directly affects the unsprung weight, which can cripple your acceleration.
Second, you should look into your overall rolling diameters. Going from 18s to 19s or 20s, the change in rolling diameters is usually negligible, but it does affect your performance and your speedometer accuracy. I recommend you use a calculator to determine the difference between your current overall rolling diameter and one you'll be switching to. This calculator will also tell you how much off your speedo will be and in which "direction".
Finally, when looking at ride quality, think of it either as a "loss of comfort" or "gain in sensitivity and control", but you'll be getting much more direct communication from your steering wheel. BMW has a pretty sensitive steering to begin with, so imagine your steering in HD and you'll get an idea. To some this might be a problem, to others - solution. I tend to side with the latter, but there's no shame in either.
My Ride: 545i Sport Package, Black/Grey. Got it July 09.
I think that depends on the weight of your wheels plus the thickness of your tires... u usually want to go with a setup that has the same (or close to it) diameter as the stock specifications.
Edit: V beat me to it with a much better (detailed) response... read his and ignore mine
Edit: V beat me to it with a much better (detailed) response... read his and ignore mine![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
Originally Posted by v_therussian' post='1019003' date='Sep 28 2009, 01:17 AM
Actually, you reminded me of something else I originally forgot: even though this is both - beneficial and detrimental, an increased contact patch will make a huge difference. On one hand, larger contact patch means more friction, translating into more resistance for the car to overcome. However, in a performance-oriented sedan, such as an e60, it is probably negligible and the gains in sensitivity, not to mention the considerable expansion in the car's handling "limits" far outweigh any detrimental effects a larger contact patch might have.
My Ride: E60 530d M-Sport
Also a problem with larger rims is that the tyre sidewalls become thinner proportionally.
Thinner the sidewall the less rim protection, the less tyre roll in hard cornering, thus more precise handling, however when you go over the limit shallower side walls snap back much harder, it gives you less warning.
This is not generally a big problem unless you start fitting staggered offsets with large width rears on 19's or 20's tho.......
My Ride: 545i/6spd
You really get what you pay for. Most larger wheels will weigh significantly more which will result in slower acceleration, worse handling and like you mentioned a larger rim will mean a slightly stiffer/rougher ride.
If you spend the big bucks you can get larger and lighter wheels which will improve your performance overall. I believe discount tire direct tells you wheel weights right on the website - so go do a little searching and see how much those weights vary. We recently talked about how they had a special on RAYS Engineering forged wheels for dirt cheap that were super light. Many of the cheapo wheels weigh nearly twice as much!!
One good route is to find some oem (not replica) wheels. Generally speaking oem wheels are pretty light so if someones getting rid of their stock 18's or 19's it could be a good upgrade. Just remember if they're replica's they weigh a lot
Implication of larger wheels??
Usually larger expense!
![Cool](https://5series.net/forums/images/smilies/cool.gif)
My Ride: '05 545 Titanium Silver, Black Leather - Nav, Logic 7, Cold weather.
Mods:
Carbon filter removed.
M5 iDrive knob.
Umnitza license plate LEDs.
MP3
40% 3M tint
ACS Anti-Roll(sway) bars
RPI Scoop
G-tech Pro RR
CF Roundels
CF Wheel caps
![Thumbs down](https://5series.net/forums/images/icons/icon13.gif)
Originally Posted by E60714' post='1018984' date='Sep 28 2009, 03:41 AM
If I were to go from the stock OEM 17" to maybe a 19" or 18" setup, what are the performance implications? Rough ride? Slower acceleration?
As for changes in acceleration - if you maintain your original and optional tire size(s) according to spec there is likely to be no discernible change since the rolling radius will remain the same. And except for a slight decrease in weight that might come from lighter wheels, higher performance tires also tend to have higher rolling resistance - that's why they are so grippy ... so one may offset the other.
I think you need to balance your driving needs with wheel/tire size. For many, appearances add to the equation as does the depth of your budget!
Good luck making your decisions ... you'll get lots of good advice and valuable opinions here
socale39
09-05-2023 08:30 AM
