Want to upgrade to LCI headlights
Old Sep 3, 2010 | 08:49 AM
IzzE60's Avatar
I am thinking of upgrading to LCI headlights. I have searched the forums and found that the retrofit kit for the wiring was wrong from BMW. Is there a fix? Does someone make the cables like bruce cables, I can just buy and plug and play? Need help cause I found a set locally and need to decide asap or they will sell to someone else! Let me know!
Old Sep 3, 2010 | 09:27 AM
PraiseTheLowered's Avatar
youll have to retrofit and have the dealer program them too
i dont know of anyone who makes the cables for them either
Old Sep 3, 2010 | 09:33 AM
BlaSTiWi's Avatar
OEM retrofit cable from BMW dealer is the least you have to worry about ... you have to get the headlights, taillights and the proper light control module and proceed w/ re-wiring them (especially the plug for the headlights) and then have the dealer do re-programming.
Old Sep 3, 2010 | 09:50 AM
IzzE60's Avatar
I head the wiring diagram for the plugs from BMW was wrong. Has this issue been updated?
Old Sep 4, 2010 | 03:10 AM
Sas's Avatar
Sas
My Ride: 520i ('04)
It really depends on witch LCI headlights you are upgrading to. Halo -> Halo , Halo -> Xenon or Halo -> Bi-Xenon.
The easiest way is Halogen to Halogen then you only need to make a cabel for connecting the old plug with the new one. So it's not gonna be Plug and Play!
I'm in the process of changing my pre LCI Halo's to LCI Halo's using this pdf as a guideline (it's in German but 1 pic sais 1000 words) and a Xenon kit.
Hope this helps.
Old Sep 4, 2010 | 06:17 AM
BlaSTiWi's Avatar
Yup ... the degree of complexity are different ... I did pre-LCI Halogen -> LCI Bi-Xenon upgrade more than a year a go and it was a tricky conversion.
But the result for sure outweigh the install problem http://forums.5serie...-my-headlights/ ...
Hope this helps.
Old Sep 4, 2010 | 06:14 PM
IzzE60's Avatar
I am gonna do a pre-LCI xenon to LCI xenon. Do I need to upgrade the tail lights also for the headlights to work?
Old Sep 5, 2010 | 05:02 AM
denissm's Avatar
My Ride: BMW 545i CSR
I have done this with a 2004 545 car with xenon no cornering lights.
This is what it cost me here in Europe:
- Headlights - around 1000 usd for pair (a lil used);
- Taillights - around 300 usd for pair (new);
- Lightmodule (this is only needed to be replaced if you have a car older than a 2005 model, if you have a model 2005 and up you do not need it!!!!!!!); - around 200 usd (a lil used)
- A set of OFFICIAL retrofit cables from BMW - about 50 usd (new);
- Reprogramming done byt a local wiz in Latvia - about 100 usd;
if you're gonna do a retrofit DO the whole BACK AND FRONT. If you only upgrade the front - the back will look terrible and work terrible too. It will give random errors, that your back blinkers are not working and they won't be working, since the light module will be programmed for the LED backlights and they consume less energy. You would only want to upgrade the back alone, but not the front alone.
With all the above performed my car now looks and WORKS from the outside like the LCI. Hope this helps dude.
Old Sep 5, 2010 | 08:12 AM
jas_r_1's Avatar
My Ride: 2006 520d - 19" 172s- Remapped - LCI taillights V6 cables - LCI xenon headlights - Denison 500 with BTA1500 - led interior lights - OEM led number plate lights Planned mods: Folding mirrors - Modmynav kit - High gloss shadowline trim -
Hope this helps.
Keeps us posted on how this goes as this will be an ideal way to get LCI headlights. Add LCI taillights with Bruce's cables and it completes the look.
Old Sep 5, 2010 | 02:46 PM
Sas's Avatar
Sas
My Ride: 520i ('04)
Yep, nice look with the LCI head lights en tail lights.
I started a topic about the pre LCI Halogen to LCI Halogen conversion
ricki_
12
Feb 8, 2020 09:50 PM
Kasmo
May 7, 2019 03:30 AM
milhouse4u
Apr 22, 2015 04:43 PM
rizwan1377
Apr 5, 2015 05:22 PM
550iwa
Mar 27, 2015 06:45 AM
