Is using a tire repair kit ok for falken 452?
How long will the tire repair kit last? Do I have to go to a rim shop so they patch the tire from the inside?
I have falken 452's 245/35/20 in the front. I found a huge bolt in it earlier. Had to take it out and use the filler. Any recommendations on what to do next?
As long as the puncture is not on the sidewall, it should be okay to get it patched. Bring it to a wheel shop and have them use a plug/patch combo from the inside.
Originally Posted by nigxdoof' post='932852' date='Jul 5 2009, 12:11 AM
No side wall. It's dead center in the tire. Now I only am able to fill the puncture and not get the patch yet. Is that ok to drive for a day or two? I'm not accessible to a patching place. ![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
My Ride: 5series
I had the same problem with a screw puncture in my front passenger falken 452 tire last year, I plugged it myself and drove couple days before getting it patched at a shop, I didn't have any problems driving on the tire plug, but I drove more cautiously (below 80mph) just in case, hope that helps.
i had a fat nail in my tire and took it sears tires.
if i remember it correctly, they guarantee the fix for as long as u own the tire.
Pretty cool stuff, u should look into it.
My Ride: See my signature
What filler did you use? Do you have 3 piece wheels? If you used fix a flat, and have 3 piece wheels, you may have to get your wheel re-siliconed.
asinner
05-06-2015 06:03 PM
DILLESTJAMZ
05-05-2015 12:56 PM
