Urgent help need on AFE cold air intake install
My Ride: 07 BMW 525i Premium Package, Xenon Lighting Package, manual Transmission. Titanium Grey, 20% Tint around the back, 70% V-Kool on front.
Planned mods: Style 71 wheels with Toyo Proxy 4 tires, Sachs suspension upgrade, upgraded stereo, and many more to come.
just install my AFE CAI, not sure if i did it right....
there's this part with a grommet and a 1/4" valve thing that i don't know where to use it for
seems like it should get plug in to the tubing that has a little hole? but it mention that i should put the vacuum line into this valve? basically the grommet with this 1/4" valve is still sitting in my trunk and i have no idea where to plug it to or what's it for
also, for the MAF, the two screws that is supplied isn't quite right. the original one is torx but this is too big for the AFE slot, so i try the supplied screw but it doesn't quite fitting right
on top of that, it seems very hard to get the tube all tight, just afraid i don't have a good seal... lastly there's a rubber piece that's like over 1' long, is that supposed to go around the filter at the housing?
hopefully someone can post about it and help. but if not, i know all the nor cal guys go to sonic motorsports. vt when he had his 545, sonic did the custom fitting of a AFE for a 550. just a suggestion.
socale39
09-05-2023 08:30 AM
thesalboy
04-08-2015 09:13 AM
