Upgrading non-sport suspension
Old Dec 17, 2007 | 01:49 PM
KnIgHtCoM's Avatar
Get some coilovers! You seem like a guy who doesn't like to fool around. With a set of KW V2's, you can adjust your ride to whatever height you desire and adjust the dampening to be as stiff or soft as you like.
A guy is selling them in the classified section for $1200. They normally retail anywhere from $1800-2300. Buy these!
Old Dec 17, 2007 | 03:26 PM
pimm's Avatar
What is the difference between the Eibach pro-kit and the sportlines ?? i would like to change mine but i am a little worried it will drop the front to low. Any other advice following this thread please !
Thanks
Old Dec 17, 2007 | 03:44 PM
spindrome's Avatar
My Ride: the family sedan...
Having recently installed H&R's on the non-sport struts, I must say that the comfort/ride quality is near stock, UNTIL you hit some speedbumps or potholes. The H&Rs (and perhaps Eibach) springs are not tuned for the non-sport struts. The H&R spring rates are stiffer than stock. Coupled with the stock non-sport dampers, you're going to get a lot of unnecessary rebound. Basically, the struts aren't dampening enough. It's good enough for daily driving, but I wouldn't dare track this car or drive it too aggressively in the twisties.
Aesthetically, the ride height is perfect. Coming from a non-sport, the drop makes the car more aggressive, especially with 19's/20's. No rubbing issues here.
I'd recommend getting either the H&Rs or Eibachs and some Koni or Bilstein's installed at the same time. The shop won't charge you more since it's actually an easier job to install new springs/struts since they don't have to remove the stock coils.
I'd shy away from coilovers unless you're really serious about tracking the car.
Old Dec 17, 2007 | 03:47 PM
C's Bimmer's Avatar
Exactly. This is what is important for folks to realize. Well said.
Old Dec 17, 2007 | 05:18 PM
vegastrashed's Avatar
Marco,
I agree with KnIgHtCoM (Ryan) and get coilovers. It'll cost more than springs but worth it in the long run. Believe me when I say this b/c I went through 3 suspensions on the 545i. A cheaper alternative to KW are Bilstein PSS9 which I had on the 545i.
Old Dec 17, 2007 | 07:17 PM
ITNurse's Avatar
My Ride: 08 535i, Platinum Gray, Sport Pkg
Thanks for the info guys.
Ryan - you've got 20's 245/F 275/R? Any issues with rubbing?
Another question: are offsets specific to each car or are offsets wheel specific? Thanks for your help with the newbie question.
Old Dec 17, 2007 | 08:07 PM
KnIgHtCoM's Avatar
I'm running 245/30 in the front and 285/25 in the rear. My fenders are rolled in the back and I have a 15mm spacer on my front wheels. Absolutely no rubbing. I 'm even considering 255/30 and 295/25 for my next set of tires.
The reason I put spacers on the front was because I wanted to push the wheels out to make them flush with the front fender and I was getting a little bit of rubbing on the inside of my wheel against the coilover when I turned the steering wheel all the way to either side because I dropped my car on the lowest setting.
Offsets are wheel specific.
Old Dec 17, 2007 | 09:23 PM
Thanks
pro-kit drops the car 1.2" all around. sportlines give a 2" drop in the front and 1.2" in the rear. if you want more info on the sportlines, try contacting snikt21 (eko). he had sportlines on his previous 530 before he went to his M.
Old Dec 26, 2007 | 03:32 AM
neocon's Avatar
Not to hijack the post, but I am looking to lower my 05 525 w/sport....I would like to lower it and add 20" rims. What kind of combo am I going to have to run to be able to do this? And nerweezy can you recommend anyone for the install?
Thanks
Old Dec 26, 2007 | 04:44 PM
Thanks
the eibach pro-kit is said to be made to work with the stock shocks and struts. many with just the pro-kit or with H&R sports have just done springs and still have the stock shocks and struts. with those springs, its a noticeable drop even though its not by much. youre still welcome to do shocks and struts with any springs you go with.
also, where are you from? if so cal, i got my springs installed by eurorev in inglewood. many members have gone to them as well.
