Underseat woofers frequency response?
Is the signal going to the under seat woofers band pass (30-500hz) or is it low pass and the woofers naturally roll off at 30hz?
the guide to the e60 says the frequency is from 30-500, but it doesn’t say if its band passed that way or if the woofer’s frequency response is that
from the guide:
”The central woofers have a diameter of 200 mm and a load bearing capacity of 40 W. The transmitted frequency is between 30 Hz and 500 Hz.”
thanks!
from the guide:
thanks!
iamnatio
03-08-2013 02:41 AM
nelson29
17
05-20-2007 08:49 PM
