Umnitza fitment issues
Originally Posted by e6t.lab.rat' post='1022760' date='Oct 2 2009, 01:16 AM
damn! this is not sounding too good. so frankly, if they don't line up we're screwed? meaning the brackets must be altered?
and by "sanding down the edges," won't that in effect elongate the hole thus causing "a loose fit?" did this solve your false beeping?
Originally Posted by mistique_M3' post='1022768' date='Oct 1 2009, 10:25 PM
No all you have to do is simply give it a light scuff to remove the sharp edge DO NOT sand inside the whole...using a scuff pad would work just fine...as long as you have patients you could get brackets to line up perfectly...just make sure your sensors are facing straight out or slightly upward so you dont have the same problem I have....havent had a chance to alter the brackets yet I've been to busy trying to complete the rest of my mods...
I just installed the Umnitza M5 front replica. Everything is great, except a portion of the area below the bumper grill sags. Any ideas on the cause of this and what adjustments to make to eliminate it?
My Ride: BMW e60
mine does the exact same thing and i got mine from trinity.... its hard to notice at first, but when you do notice it, its like :S WTF
My Ride: 2006 titanium silver metallic
Like new 41k
Cold Weather Package
My Ride: 2005 545i
Originally Posted by e6t.lab.rat' post='1022744' date='Oct 1 2009, 11:51 PM
OP, thanks for sharing this.
could you let us know how much of a hassle (if any) did the shop encounter while relocating the brackets? I surely hope I dont have this problem as i will attempt to install this myself. what quads are you planning on getting? looking forward to those pics (try to show the sides (hopefully without) the gaps, and especially the rear bumper without the quads.
good luck and thanx once again. ![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
Sorry for the late reply... but my shop had painted before test fitting just to get the job done faster. They had to take off the brackets, sand a lil here and there so the sensors fit correctly and reapply the brackets. They said the headlight washers were going to be a huge pain, so I told them to just not even reinstall them. Im okay not having those anyways.
The side skirts are like 5mm short on the front towards the fender. Another poster in this thread didnt notice even, I just happen to look real close at everything and noticed it. Otherwise they look great.
My shop also had to sand down the edges on the PDC holes because some were sharper than others. That was an easy fix.
My quad set up is still not installed but I am going with a 2in 2out magnaflow muffler with internal x pipe. I am going to keep the stock resonators, have this muffler be installed midline and have pipes split from there and each go to a jones perforated turbo tube each, and then to 3.5 inch dual tips on each end.
I havnt had my car for a month because I bent a wheel and my wheel shop has been so backed up and my car has been out of order due to that. I will post pics soon.
Other than the using the Mtech headlight washer levers, are there any other parts that need to be purchased to make the Umnitza front bumper fit perfectly? (i.e. the "adapter" that is listed in the realoem diagram, etc...)
