tyre expert advice needed
i am going to fit 19" wheels with 275/30 and 245/35. Compared the strandard tyres to the new ones. Here are the results. Is it ok? there is not big differences between the new and old tyres in most of the categories.
can someone just confirm that there ok?
thanks
thanks
Your new setup does not result in a wheel/tire combo that is appreciable bigger than the standard ones. So the should not rub.
My setup is 8.5x19 ET13 245/35 FRONT, 9.5x19 ET20 275/30 REAR.
Works absolutely perfect.
Can experiencing small rubbing at full compression of the suspension when at the same time turning into a sharp bend. Just like on Nurburgring last week
Be sure to check that you get a offset that works OK.
