Trunk handle idea
My Ride: G30 M550i
Model Year: 2018
I'm not a fan of license plate frames at all. It seems to me that using them just calls attention to something that you're trying to ignore.
If you're primary reason for using this is for the "handle," you need to practice using the handles BMW has provided already on the inside of the trunk. Most people don't know about these so they never use them. Others know about them but can't figure out how they work.
It's simple, the trick is to grab one and swiftly pull straight down with your elbow bent about 90 degrees. As you pull down, you'r arm will naturally swing out of the way and the trunk will close. All you really need to practice is the force in which you pull.
Trust me when I say that I've not touched any paint (or dirty license plate) while closing a trunk since 1998 (using the handle on the E39.)
My Ride: 2004 525i Jet Black on Grey Interior---
Tint: Sides 20% Rear Windshield 5% Front Windshield 35%
Wheels: Zenetti Five's 20" by 8.5(front) 20" by 10(rear)--
Tires: Pirelli Asimmetrico 245/35/20(front) 285/30/20(rear)--
Body: Hamann Full Front Spoiler, Rieger Side Skirts, Rieger Rear Apron, AC Schnitzer Trunk Wing
Interior: AC Schnitzer Pedal Set and E-Break
Springs: H&R Sport Springs--
Audio: 2 12" Kicker L7's with a Rockford Fosgate 1501bd Amp With Custom Trunk Enclosure
SOON TO COME:
-M5 Mirrors
-M5 Trunk Finsher
-Brembo GT Big Brake Kit
-Hamann 6 Series Front Spliter Molded
-Hamann Roof Wing
-Full Custom Sound System with TV's
ehhh not a bad idea but I personally don't like frames around the plate... like Rudy stated I sometimes use that lever on the inside of the trunk.. or I just use the old hand on liscence plate theory I never...EVER touch the paint as well and when people go to close my trunk by the paint I slap their hands
Originally Posted by Rudy' date='Jan 3 2005, 05:24 AM
I'm not a fan of license plate frames at all.? It seems to me that using them just calls attention to something that you're trying to ignore.
If you're primary reason for using this is for the "handle," you need to practice using the handles BMW has provided already on the inside of the trunk.? Most people don't know about these so they never use them.? Others know about them but can't figure out how they work.
It's simple, the trick is to grab one and swiftly pull straight down with your elbow bent about 90 degrees.? As you pull down, you'r arm will naturally swing out of the way and the trunk will close.? All you really need to practice is the force in which you pull.?
[snapback]75012[/snapback]
My Ride: F02 LCI Individual
Model Year: 2013
Originally Posted by alohalc' date='Jan 3 2005, 11:44 PM
...i asked my tech to adjust it a bit but he refused...
[snapback]75175[/snapback]
It is easy to adjust the springs, BMW designed them to be adjusted. In the pic you can see where the spring can be adjusted...
since i've built up a so-called good relationship (means tips from me) with him when i was there last time. i think i'll ask him again when i'm there next time. wish me luck .
My Ride: MY 2004 545i; April build; 6 speed; silver grey metalic; black leather; poplar; sport package; cold weather; active steering; xenons .
Awest91
09-17-2022 11:05 PM
incoherent
04-15-2015 04:48 PM
