tires/20" collectizone and rubbing issues? *pix*
I just wanted to know if I lowered my 2005 525i with the eibach prokit springs or H&R if it will rub with a 285/30/20 falkans 452 (rears) and 245/30/20 (fronts) set-up. any recommendations on which springs to buy and what will i need in addition to the springs to avoid rubbing? thank you in advance for your responses.
![tires/20" collectizone and rubbing issues? *pix*-img_6679.jpg](https://5series.net/forums/attachments/e60-e61-parts-accessories-mods-22/46048d1482366039t-tires-20-collectizone-rubbing-issues-%2Apix%2A-img_6679.jpg)
![tires/20" collectizone and rubbing issues? *pix*-img_6680.jpg](https://5series.net/forums/attachments/e60-e61-parts-accessories-mods-22/46049d1482366039t-tires-20-collectizone-rubbing-issues-%2Apix%2A-img_6680.jpg)
![tires/20" collectizone and rubbing issues? *pix*-img_6681.jpg](https://5series.net/forums/attachments/e60-e61-parts-accessories-mods-22/46050d1482366039t-tires-20-collectizone-rubbing-issues-%2Apix%2A-img_6681.jpg)
![tires/20" collectizone and rubbing issues? *pix*-img_6682.jpg](https://5series.net/forums/attachments/e60-e61-parts-accessories-mods-22/46051d1482366039t-tires-20-collectizone-rubbing-issues-%2Apix%2A-img_6682.jpg)
I'm running FSD Shocks and Eibah Pro Series Springs right now with 20" Hartge Classic 2. I dono the exact tyre specs, I"ll check it out and get back to you in a few hours.
Originally Posted by 525iSE' post='543364' date='Mar 12 2008, 01:03 AM
I'm running FSD Shocks and Eibah Pro Series Springs right now with 20" Hartge Classic 2. I dono the exact tyre specs, I"ll check it out and get back to you in a few hours. ![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
Originally Posted by 525iSE' post='543470' date='Mar 12 2008, 08:01 AM
Ok got my tyre specs. Sorry for the super late delay. My front is 245/35/20 and my rear is 275/30/20. No rubbing issues whatsoever. Runs perfect. ![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
Welcome back 525iSE! Where are the pics of your new ride?
What compelled you to come back? Mbenz just wasn't cutting it?
Btw, whats the offset for your 20's? I plan on getting a set soon and I have mine lowered with Eibach Pro-Kit. with the same specs, 245/35/20 in the front and 275/30/20 in the rear. Also I plan on changing my shocks. Still stock shocks. What would you recommened? I still want to keep the Eiback Pro Kit springs.
Koni's? Bilsteins?
@flybeam52
I recommend you change the shocks. the Koni FSDs are great in my opinion.
@nigxdoof
Thanks for the welcome. MB was really fun, but I got a really good deal for the 520d (only diesel model in Thailand :thumbsdown
and I really wanted to try out diesel. After ecu remapped and sprint booster installed, it was just too fun. Didn't care too much about the LCI, I could just do the LCI lights conversion and I"m set.
As for the offsets, I got the original classic 2 from Hartge, so I believe its front offset 18 and rear offset 22 according to www.hartge.de but I didn't run their recommended tyre specs. For the pics, I'm waiting to do my quads exhaust with new diffuser or M5 rear, not sure yet. Plus I can't find my camera charger
I'll get the pics up ASAP.
@nigxdoof
My Ride: E60 520i
flybeam52.... what causes your wheel to rub is not only depends on your tire size... offset is the most important...
u can be running on 245 all round but with wrong offset... you will still rub
btw its better than you run on 285/25/20 rears
PrimeTimeTSA
08-15-2015 02:14 PM
BigxPx
05-30-2015 07:51 AM
