Tire size help, noob and need advise!
I am very stuck between what tire sizes to run on my car.
Car is a 545i with coilovers installed
My rims are
20x8.5 et20 front
20x10 et20 rear
At first i wanted to run a stretch tire look but then opted out of it because the roads in chicago are pretty crappy after this winter so i decided on a more meaty/aggressive look, and to protect the rims as well.
The tires im looking at now are 255/35 front and 285/30 rear. ( i do know that my speedometer will be off by about 4.5% and i am fine with that )
Anyone run these sizes without rubbing?
Will i need to roll my fenders? ( i am lowered on coilovers )
and will those tires be enough for rim protection or will i have to go wider in the back?
Suggestions?
Any help is appreciated
My rims are
20x8.5 et20 front
20x10 et20 rear
Suggestions?
according to rolling diameter you should be running a 245/30/20 and a 275/25/20. we usually recommend 245/35/20 and 275/30/20 for more rubber/rim protection, but will more than likely have you rub. you can always have the fenders rolled though to cure the rubbing.
My Ride: 2008 AW N52 with sports package & premium package; natural brown interior
MODs:
Orion V2s
3000K H8 Yellow Fogs
Matte Black Kidney Grills
20" Miro 111
Hankook V12 Tires
H&R Sport Springs
Special coding via Simon (dbl flash hazards, digital velocity, etc.)
LED Side Markers from Trinity Autosports
LED License Plate Lights from Trinity Autosports
Carbon Delete
BMC Air Filter
RPI Scoop
RPI GT Exhaust
Future MODs:
Mtech Kit
KW Variant 2 Coilovers
CIC Retrofit
Upgrade Audio System
+1
Well i went with 245/35/20 in the front and 285/30/20 in the back. Im lowered where there is only maybe a quarter inch gap between the tires and the fenders and i only get slight rub in the back on big dips. Otherwise absolutly no problems with those offsets and glad i went with those tire sizes.
Wheels are so far out in the front and back i dont even need spacers unless i want a very tight fitment with rolled fenders.
My Ride: 2005 545 6MT
asinner
05-06-2015 06:03 PM
tcast305
06-10-2004 05:50 AM
