Tire recommendations for 545
My Ride: 2005 545, Titanium Gray II, 6 Spd, CWP, Sat, LPP Laser Defense, V1 (hard-wired), iPod, 38% ceramic tint, CDV delete, H&R Street Performance Coil Overs, Forced Air Induction, DriveData Pro Camera System (4 cams), M5 Front Bumper
Thanks for the replies. I'm probably spending too much time trying to decide what to do but here are a few responses and follow up questions. As for how I drive, not a ton of miles (maybe 15k a year), but I drive aggressively. I got a 6 speed 8 cylinder for a reason.
The tires on the car now are Dunlop run flats. The fronts need to be replaced. Back tires have some more time. Is it a bad idea to have new non-run flats on the front and old run flats on the back until the backs are worn out? I'm considering putting some Michelins on the front and would rather not replace all 4 if I don't have to.
Also, does anyone have any recommendations for Michelins? AS Plus? PS2? I don't really know the difference between all season and summer tires, but I'm in GA and don't drive in snow or ice.
Any suggestions would be appreciated. Thanks!
Tires are a very personal thing to most people who care enough to actually choose their tires (i.e. most people don't have a clue, but those who do tend to have a wide range of opinions). For what it's worth, I have run Dunlop run flats on my 545 (I don't recall which model Dunlop), Blizzaks, stock tires, and a few others. My favorites by far to date are the Michelin PS2's for summer tires and Michelin Alpina for winter. They are expensive but - IMHO - worth the cost in terms of what you get in performance. Since you are in GA, you should be good with just PS2's. On the occassion that you get ice (which is not unheard of from what I recall), you probably would not want to drive your nice car no matter what shoes it's wearing.
Regardless of your choice, I would recommend that you forego run flats and get yourself an M-Mobility kit. It comes standard with the M5 but you can purchase one for about $125-$150. The kit includes an air compressor and basically a Fix-a-Flat bundled in a nice small carrying case. The compressor plugs into your cig lighter (there's one in the trunk of the car in case you have never seen it). The bag/kit fits nicely in the spare wheel compartment after removing the dead weight that is your under-sized spare. At least that is what I did. If you've got one of the newer 5ers, I suspect your car never came with a spare to begin with thanks to the BMW bean counters.
Regards,
RR
My Ride: See my signature
Price no object summer performance tires: Michelin PS2
Price no object AS tires. Michelin Pilot Sport A/S
Discount summer performance tires: Hanook Ventus V12 Evo
Discount AS tires: General Exclaim UHP
Tirerack.com usually has the lowest prices for new tires
Happy hunting!
Happy hunting!
Happy hunting!
Happy hunting!
One more comment, I've been reading about the Hankooks and they sound good although the tread wear concerns me. I just called a local tire place and they advised me to spend the extra money and get Michelins instead of Hankooks. Sounds like you are happy with them. I'm definitely not ruling them out.
Local tire guys will always recommend brand names, it' safe and it's not their money. Dunno if you looked some direct comps. On some of these tests the Hankooks beatign Michelins in many categories.
It's gotten quite wet out here in SoCal this season, and I have not had any slippages or hydroplaning with hankooks. I basically drive freely passing others at will without hesitattion in the pouring rain. My older shoes, Nitto NT555=junk, tread wasn't great 40% left, I couldn't let loose in the wet.
You have choices. The other quality I like is that hankooks are somewhat soft and comfy for 20 inch, I'd wonder how much better ride would be with 18" stock wheels.
GL
http://www.caranddriver.com/var/ezfl...fa4477cd02.pdf
http://www.caranddriver.com/var/ezfl...db6d08bbf2.pdf
http://www.caranddriver.com/var/ezfl...5364f66014.pdf
http://www.caranddriver.com/var/ezfl...7d182ef955.pdf
http://www.caranddriver.com/var/ezfl...ecd0eaf943.pdf
http://www.caranddriver.com/var/ezfl...66f4a3c932.pdf
Hey Jagerman,
GL
http://www.caranddri...7fa4477cd02.pdf
http://www.caranddri...cdb6d08bbf2.pdf
http://www.caranddri...f5364f66014.pdf
http://www.caranddri...87d182ef955.pdf
http://www.caranddri...6ecd0eaf943.pdf
http://www.caranddri...866f4a3c932.pdf
GL
http://www.tirerack.com/survey/Surve...irePageLocQty=
Michelins http://www.tirerack.com/tires/tires....ilot+Sport+PS2
Hankooks http://www.tirerack.com/tires/tires....s+V12+evo+K110
I looked at all these data before I made my choice.
Cheers!
My Ride: 2006 BMW 550i "Ben Hogan's 5 Iron"
SilverGrey/Black Sport, L7, NAV, CW, AS, Split FR
2003 Audi A4 3.0 CVT "Part of the Moniker"
Silver/Ebony, Prem, CW, Star 17s
I'm sure this topic has been covered before, but I would appreciate any recommendations for tires for my 545. I had a tire blow out on Friday and probably need to replace all 4. I'm pretty well decided against run flats.
Also, when the tire blew out, there was no indication of a problem on the Idrive. When I got the temporary tire on the Idrive then indicated a flat. I thought this was odd.
Only negative is hum at 40mph but maybe more break in time is needed. 100 miles so far.
Last item. They are much smoother than rfts but I'm missing the quick turn in of the bridgestones just a bit. Rfts felt real aggressive firmwise. But the goodyears are a good trade off and indicator stalk isn't rattling as much over bumps.
$800 net of rebate wasn't bad pricewise.
