Tire Pressure
My Ride: E60525i: Logic 7, Premium Package, Cold Weather Package, CIC Retrofit, OEM Nav activation, new controller, Combox, 6FL/6NR , Heated Steering Wheel, 6 Speed STEPTRONIC, Bluetooth, 6 CD Changer, Escort 8500 X50 Hardwired, Remus Exhaust, 35% tint, Alufe
So I've been reading alot of about tire pressures and their impact on rim protection. Just curious what pressures you guys are running your 245/35/19 + 275/30/19 tires at. Thank you.
My Ride: 2008 AW N52 with sports package & premium package; natural brown interior
MODs:
Orion V2s
3000K H8 Yellow Fogs
Matte Black Kidney Grills
20" Miro 111
Hankook V12 Tires
H&R Sport Springs
Special coding via Simon (dbl flash hazards, digital velocity, etc.)
LED Side Markers from Trinity Autosports
LED License Plate Lights from Trinity Autosports
Carbon Delete
BMC Air Filter
RPI Scoop
RPI GT Exhaust
Future MODs:
Mtech Kit
KW Variant 2 Coilovers
CIC Retrofit
Upgrade Audio System
So lowering or raising the recommended psi helps? The other day I my flat light came on went to the flat fix shop and he discovered a nail in the tire while i was there I made him balance my tires and he informed me that I was driving around with about 7 to 8 psi low on each tire I didn't even know that so naturally I told him to fix them but i hate how the ride feels now it feels bumpy and less absorbing to pot holes
I'll take a bumpy ride over a bent wheel any day of the week. What was your pressure before, and what is it now? Also, what wheel/tire set up are you running?
I recommend maintaining tire inflation pressures at or no more than 2-3 psi above that recommended on the driver side door jamb.I do not recommend running lower psi than the same sticker lists.
take vehicle weight 5 series 4000lbs/4 =1000lb per tire load
take 1000/load index... so 1000/1565(hankook 275/30) =.63
take .63* max tire pressure.. .63*50=31.94psi...
So minumum tire pressure is 32psi
I would run 35-39 all the way around!
