sws-8 earthquakes
My Ride: 2006 530i mystic blue
i plan on running these to the stock amp and leaving my other highs to my aftermarket amps. what ohm sws-8 should i get i ordered the 4ohms but if i need the 2 i gotta switch the order real quick. the 8's do fit in the 6.5 holes right!
My Ride: F10 M-Sport
Model Year: 2014
With the earthquakes I believe you may need the 2-ohm....perhaps someone else can chime in.
My Ride: 2005 530i Silver Gray/ Gray Leather. SP,PP
Where are you getting 6.5 from? The subs underseats are 8" subs and are 2 ohms, so if you planning to run the OEM amp you will need to get the 2 ohm version of the sws's. My question to you is why don't you run a better amp to the sws?
i was looking at my underseat grills and they were diffrent looking then some i seen pics of like mine are rectangle while some i seen were like a 6 point shape. i read somewhere they were 6.5 phillip mid driver under there but the 8 would fit because theres a bracket allowing the 6.5 to hit in there. i dunno. either way i ordered the 4 ohm sws-8's because im going to run them to a alpine pdx 5 channel amps. the 75x4 on my highes the 300x1 imma run the sws-8s at 150 a peice. that way all my amps are pdx series and matching.
My Ride: 2004 BMW 545i 6mt, Titanium Silver, Sport Package, Winter Package
They sound like crap. The oem subs sound better than the sws-8 when using the oem amp. There... I said it!
tru ive read that somewhere too. im assuming because the oem amp isnt powiring them enough and when u turn the volume up the lack off wattage just ditorts them. imma hook them up to a amp tho should see 100 watts each
My Ride: M3
Model Year: 2017
Of course they sound like crap with the OEM amp... 40W max to each SWS-8 is nothing as they are not sensitive at all. They require at least 5 times that power (200W max/100W RMS).
haugejan
10
12-19-2010 01:59 AM
Vpower
03-13-2008 10:37 PM
gIzzE
02-28-2008 10:31 AM
Deano
19
12-08-2007 07:23 AM
