Style 124's FTM --> TPMS ???
Originally Posted by medik13' post='1096345' date='Jan 23 2010, 12:44 PM
Please help. I am about to buy these wheels but need to know if I can just add my old TPM sensors to the wheels. Will they fit and work properly?
My Ride: e60
the tpms sensor is a specialized valve stem and radio transmitter
they can be taken in and out and exchanged between oem and custom wheels
ftm... what his car has (not his wheels)
is a different tire pressure sensing technology that deals with abs and gives u no real data in ur car
ie. tire pressure
Originally Posted by medik13' post='1096382' date='Jan 23 2010, 05:32 PM
Thank you...I was just worried they wouldn't fit into the holes.
A word of advice, the gaskets, xmiter and stem have to be assembled correctly on the wheel or the stem will leak! An experienced tire installer has to know what he/she's doing. This is a little different than pulling a rubber tire valve through the hole on a wheel! Ask me how I know
My Ride: e60
they r easier than u think
:l
the removing of the tire and placing of the tire onto the wheel is where the technical part comes in
someone not aware of sensors in a wheel can crack the housing making them inoperable
but the actually removal of the sensor u dont even really have to remove the tire
just press on its sidewall untill the sensor is reviled and with a socket and ratchet, undo it
if the value is seemingly stuck in there...
give it a lil tap with the ratchet, careful not to hit ur wheel or let it fall into the tire (then ull have to remove it)
i doubt u will be doing all this
just fyi
:l
just fyi
Trinity Autosport
09-22-2016 11:08 PM
DetailersDomain
Detailing Forum
09-22-2015 03:59 PM
umnitza
09-02-2015 11:28 AM
