Step Shifter Removal
Old 08-20-2008, 04:59 PM
bespoke1's Avatar
My Ride:
Have used search and found very good info on the removal of e brake handle. Nothing on Step shifter......
Is it as simple as pulling it off???
Sounds too good to be true.
ACS set up on the way....
B
Old 08-20-2008, 05:04 PM
DRANGED's Avatar
It is as simple as that, just pull. Make sure to have your face out of harms way when it lets loose.
Old 08-20-2008, 05:08 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Correct, except be very careful to not twist the lever at all -- just pull straight up...
knob_for_shift_lever.pdf
Old 08-20-2008, 05:11 PM
bespoke1's Avatar
My Ride:
Attachment 57499
great, thanks you guys!!
Old 08-20-2008, 05:40 PM
CWS530's Avatar
That's what SHE said!
Old 08-20-2008, 05:42 PM
DRANGED's Avatar
Set you up perfectly!
Old 08-21-2008, 12:00 AM
flyingpuck's Avatar
TFF!!
Old 08-21-2008, 04:40 AM
1esquire's Avatar
My Ride: 2009 DINAN 135 convertible
+1, I got a bloody nose and busted lip when I was pulling my knob off. It let loose, and I punched myself straight in the face.
Old 08-21-2008, 05:12 AM
bespoke1's Avatar
My Ride:
Huh, maybe I'll have a friend come over and 'help out'..........
Old 08-21-2008, 06:49 AM
easiest way how I did it was turn the key and put the shifter into neutral, that way you pull straight up. if it was in park, it would be a bit at an angle. just sit regularly, grab the knob with one or two hands and pull straight up keeping your head out of the way . (I hope I didnt set anything up )
Quick Reply: Step Shifter Removal
