Steering wheel button part number
Does anybody know the part number for #8 in this image? RealOEM doesn't have anything. The image comes from Real OEM under Electrical Systems and Switches.
Neither buttons on my steering wheel are working and I think this wire is the problem.
My Ride: 2008 550i M-sport, retrofitted heated M-sport steering wheel with paddles, Sport-auto transmission
61316959355 - no/no (heat/SAT)
61316959356 - yes/no
61316976397 - yes/yes
61316976396 - no/yes
You can also try searching for "Wiring set, steering wheel"
Good luck!
You should also check the bmwfans.info site, as it sometimes has additional information on parts that isn't on realoem.com - like which parts can replace superceded parts, etc. I did a quick check for a pre-LCI 545i, and it did have the various part numbers for the wiring set - so you should be able to find what you need there (again, 4 versions depending on options).
DavaiLave
Aug 2, 2022 02:16 AM
BYS2
Mar 24, 2015 03:13 AM
