SSS CCC retrofit programming - part numbers?
When trying to use SSS Progman to update the software on my car im getting the following, and cant progress any further:
I have replaced the CCC/added heated seats and button module for heated seats. These need to be programmed.....
HELP PLEASE
Status report
Vehicle data status:
E060-06-06-510
Target data status:
E060-08-09-530
Following ctrl mod.s have failed to respond or have responded incorr..
AUD
has failed to respond/responded incorrectly
CHAMP-S/M-ASK-S
CHAMP-/CIC-/M-ASK-H
GW
must be replaced
Part no., progr. ctrl mod.:
9185627 (is)
9195750 (should)
BO
must be replaced
9185623 (is)
9195745 (should)
CON
must be replaced
6941801 (is)
6944884 (should)
CID
must be replaced
9114356 (is)
9151975 (should)
CAS
must be reprogrammed
6943797 (is)
9147214 (should)
SGM-ZGM/KGM
9118730 (is)
9186172 (should)
SGM-SIM/ACSM
9118931 (is)
9172019 (should)
DME/DDE
7803666 (is)
7811743 (should)
DSC
6775732 (is)
6777799 (should)
EHC
6769834 (is)
6784314 (should)
PDC
6978232 (is)
9185139 (should)
RLS
6980019 (is)
9120309 (should)
KOMBI
6983154 (is)
9197107 (should)
KBM
9114448 (is)
9176070 (should)
DWA
6980089 (is)
9149673 (should)
SZM
6985750 (is)
9155287 (should)
HELP PLEASE
Status report
E060-06-06-510
Target data status:
E060-08-09-530
AUD
CHAMP-S/M-ASK-S
CHAMP-/CIC-/M-ASK-H
GW
must be replaced
9185627 (is)
9195750 (should)
BO
must be replaced
9185623 (is)
9195745 (should)
CON
must be replaced
6941801 (is)
6944884 (should)
CID
must be replaced
9114356 (is)
9151975 (should)
CAS
6943797 (is)
9147214 (should)
SGM-ZGM/KGM
9118730 (is)
9186172 (should)
SGM-SIM/ACSM
9118931 (is)
9172019 (should)
DME/DDE
7803666 (is)
7811743 (should)
DSC
6775732 (is)
6777799 (should)
EHC
6769834 (is)
6784314 (should)
PDC
6978232 (is)
9185139 (should)
RLS
6980019 (is)
9120309 (should)
KOMBI
6983154 (is)
9197107 (should)
KBM
9114448 (is)
9176070 (should)
DWA
6980089 (is)
9149673 (should)
SZM
6985750 (is)
9155287 (should)
Hello. The problem you are having is because your vehicle's network has been disrupted.
This is most likely done by a dealer who did service and did some updates to the car, updating some part numbers and not others. Anytime this is done, the complete vehicle should be encoded.
Unfortuately, you will need to do this manually.
First you will need to determine your vehicle's i-level. Progman has done this for you.
E060-06-06-510
Target data status:
E060-08-09-530
This will determine which data set you will need to program the car with.
You will need to manually adapt the FA and then marry all of the control modules to accept the new vehicle order. This can be done by WINKFP. If you want permantly resolve this issue you can manually update each module with the correct zbnumber and then marry the entire network together. It is quite a task though if one is not familiar with how to do this or has never done this.
E060-06-06-510
Target data status:
E060-08-09-530
E060-06-06-510
Target data status:
E060-08-09-530
E060-06-06-510
Target data status:
E060-08-09-530
Thanks started pairing the parts to the VIN, only ones left to programme with winkfp
are CCC unit and BZM/SZM.
Only problem is the BZM/SZM, it is asking for the following file when using ZB 9155287:
080100SZM60.ipo
anyone got this file?
DavaiLave
08-02-2022 02:16 AM
madein
06-06-2015 11:48 AM
BYS2
03-24-2015 03:13 AM
