springs how long can u go
Originally Posted by qtrII6' date='Aug 2 2005, 03:24 PM
sorry ppl i cant spell how low not long can you go lol also i was wondering anyone do this themselves? was it hard should i have someone do it for me or is this a cake walk
[snapback]155472[/snapback]
As to how low you can, I'm not really familiar with the stock spring rates for the E60, but if you just swap about the springs without getting new shocks, you'll get premature wear on your suspension system, run negative camber (meaning you'll wear out your expensive 20 tires prematurely with uneven wear), and maybe even some rubbing.
Without knowing the exact numbers, I'm guessing you can drop less than 1 inch without much problems if you get an alignment soon thereafter.
Ejceles
08-13-2015 04:42 PM
ArnottInc
08-03-2015 12:42 PM
