4 Attachment(s)
...some of you guys might have seen, but on day 1 I took my car apart and did the m5 retrofit. My car is now a week old and my confidence is sky high so I went to the dealer on wednesday and ordered the following parts that I picked up today :D
Attachment 50692 Attachment 50693 Attachment 50694 Attachment 50695 There are 3 stages to this exercise Stage 1: retrofit just the SAT lever and the ECU with no SAT functionality Stage 2: have the car coded for SAT functionality (Sports mode, faster shift times etc.) Stage 3: paddle shifter retrofit Stage 1 is due this weekend. I am 50/50 on whether stage 1 will work. My engineering background tells me, it should not work because the ECU has no firmware running on it so it will not work. Let us see - more to come later.. wish me luck :) cu rumman |
Is this the "kit" you PMed me about -- the one where a BMW dealer had retrofitted the SAT on a 535d? If so, hopefully they gave you good advice and instructions... GOOD LUCK!! :thumbsup:
this is not a retrofit kit, but I will make it one...
if all goes well, I will post DIY on the forum... wish me luck |
This I think will be the first, awesome. Very best of luck. Keep us posted :number1:
Is this compatible with Pre-LCI cars as well, or just only for LCI with standard Auto? :think:
Originally Posted by rsyed' post='581897' date='May 16 2008, 04:25 PM
no no, it is only for LCI cars with the standard "ugly" automatic shifter...
Is the only difference with the sports automatic transmission the selector lever and ecu then? Seems it must be the only difference after looking at bmws site the sport auto is only another ?100 on the 535d.
Yes, the difference is the ECU and selecter lever, and the Sports button
As said, stage 1 is to get this thing physically in. Stage 2 is to get the dealer to enable the SAT features on my car. And Stage 3 are the paddles... cheers |
| All times are GMT -8. The time now is 07:41 PM. |
