Spare Tire for M5 BBK
My Ride: 545i Sport
Engine: N62
Spare Tire will not fit due to bigger brake caliper (switched from 545i to M5 front brakes).
Solution: Use of 20mm+ H&R spacers and longer bolts. Thanks Russ(E60_545i_SPORT)
Now I have to put the heavy donut back in the trunk but I can drive the car to a tire shop/store when
I need to . Hope I don't have to use it in the future. Knock on wood !!!
Russ still has a pair of 20mm spacers with long bolts. 2 people with BBK can split the cost for this setup.(1 20mm spacer and 5 bolts)
My Ride: honda accord
i have the same dilemma....would this spacer trick work with the brembo kits?
i had a blow out one time and had to get towed cuz my spares couldnt fit
My Ride: 545i Sport
Engine: N62
The clearance is really close. Now my trunk is a little heavier with the donut, spacers
and bolts. GL.
My Ride: .
Model Year: .
Originally Posted by Rizbel' post='878846' date='May 14 2009, 09:18 PM
... Now my trunk is a little heavier with the donut, spacers and bolts. GL.
My Ride: 545i Sport
Engine: N62
Originally Posted by mrfva' post='878899' date='May 14 2009, 08:13 PM
You can remove your floormats to compensate for the extra weight in the trunk
FS: BMW OEM Rear Rubber Floor Mats Front and Rear. (I'm not kidding)
BTW, Relisted - 2008 M5 Front Brake Kit OEM
DavaiLave
08-02-2022 02:16 AM
