Spacers for my rims
My rims are too wide in the front and were scraping on my strut. I found some thin (5mm) spacers that are direct fit (not universal). I have heard about spacers causing vibration and do not want to have a crappy ride on a BMW. So I want to know if spacers really cause vibration and what would be my other options other than spacers.
Thanks
Thanks
My Ride: 2007 Alpine White 530i
to be honest I have 15mm spacers from Sonic Tuning, I never really had an issue with the ride after I put them on. In terms of options... I think spacers is the only solution unless you want to get new wheels.
My Ride: 2008 E60 528i
6MT, Sports Package, Premium Package, Navigation
it depends on the quality of the spacers. some can cause vibrations if they do not sit flush against the hub or your rim. have you noticed any change in ride since you put them on?
My Ride: 2006 530i mystic blue
i had the same issue with the inner tire,wheel barely touching the strut on my ksports. simply had to not go as low as i wanted. as long as it clears by 1 mm your good since they go up and down in unison
I havent put them on yet. But I need them in order to put my front wheels. These spacers I found do sit flush. It's a place that sells spacers only. Look to be good quality.
So long as your using a reputable set of spacers, you should not have any issues. We carry H&R spacers as they are one of the best that are out there!
![](http://www.modbargains.com/images/Products/HR_Suspension/HR-BMW-SpacersS.jpg)
H&R 3 Series Spacer Benefits
Up to 70% lighter than competitor spacers
Improve appearance without buying new wheels
Improves handling by widening vehicle track
Anodized for tough and durable finish
Hub centric for accuracy and no vibrations
100% made in Germany, AND TUV approved
ISO9001 approved
ISO9001 approved
ISO9001 approved
ISO9001 approved
Vman33
03-14-2022 04:43 AM
bestofthebest
03-28-2016 02:47 PM
