Should I buy a Camber kit
My Ride: E60
Lowered my car on coilovers and now have negative chamber. Got it aligned but its still -1.02 in front and -2.22 in rear. Should I buy a camber kit to bring it down? Don't want my brand new tires burned on the inside after 10k miles. Or should I raise it a little and get it realigned. How much more can I adjust the camber on a 2004 530i?
Thanks
Thanks
Why buy a camber kit? The numbers you listed are spec for BMWs. Now you CAN get teh alignment shop to dial out as much as possible to help with rear tire wear. I went from -2.1 to -0.8 when I requested them to dial it out - no camber kit needed.
My Ride: 06 530i
Now when you say "dial it out" what exactly are you talking about? The reason why I'm asking is I'm about to lower mine and I was wondering the same exact thing as the OP. do I just tell the BMW techs to dial it out or do I need additional parts to get it that way? Thanks for your help!!!
My Ride: E60
Engine: N52
There is some adjustability without having to buy a camber kit if the techs know what they are doing.
