Short Shifter choice
Thanks for the write up.
I will do the CDV when I'm changing brake fluid since I will need to bleed the clutch anyway. I think I will hold off on doing the short shifter, it sounds like a pretty big job and would be really tough without a hoist!
Have you looked at also getting a shorter knob to go with the short shifter? I have a ///M knob that is weighted and probably 3/4" shorter than stock. It was a nice improvement with the stock shifter.
My Ride: 2013 M5 - Sakhir Orange / Black Leather.
My Ride: 2005 545i, sport, nav, cold pakge, stereo, 3.45 rear, CAI, throttle bodies, software, DINAN badge, 166 wheels w/dark grey powdercoat (always look clean!).
I have 545i w/manual & UUC and it works great. I was told not to use the adjustable portion as it was too short. Solid, good feel & fast shifting. Go the new DSSR route if you do. I had rogue on my E36's and they were great too! You win either way....
My Ride: 2004 545i, sports package, logic 7 + changer, dvd navi, front heated seats + steering wheel
for those that have done this mod, what operation requires the car to be so high(on a hoist/lift)? removing the exhaust? body panels? just having access underneath the car to work on?
Originally Posted by pa550' post='419219' date='Apr 29 2007, 04:25 PM
You have to remove the exhaust in order to remove the heat shields so you can get access to the transmission. I would only do it on a hoist. Jack stands won't get the car high enough.
it is not possible to remove the exhaust mounting hardware, and then move the exhaust out of the way to remove the heat shields?
I know it would be easier without the whole exhaust, just seeing if this way would be feasible
