Shocks & Springs for the E60
Old Oct 11, 2005 | 05:04 PM
choi000's Avatar
My Ride: 2004 545i 6spd, blk on blk, HRE 540R 20x9 in front and 20x10 in rear with Pirelli PZero Neros 245/25/20 front and 295/25/20 rear. H&R springs, and Eisenmann quad exhaust, V! radar detector, black grille, limo tint all around.
Hi all,
I am looking to buy a set of aftermarket shocks to go with my H&R Springs but I have not found any companies that make shocks for the E60. Does anyone know if there are any shops out there that does make shocks? I know H&R & Koni have coilovers for the E60, but I don't feel like spending that kind of cash right now. Thanks!
Old Oct 11, 2005 | 10:58 PM
soc_fans's Avatar
Originally Posted by choi000' date='Oct 11 2005, 08:04 PM
Hi all,
[snapback]182964[/snapback]
Yes Koni has shocks for E60 already. Unfortunately i heard it is made for stock springs and not recommended for lowering springs.
Old Oct 12, 2005 | 08:25 PM
choi000's Avatar
Originally Posted by soc_fans' date='Oct 11 2005, 10:58 PM
[quote name='choi000' date='Oct 11 2005, 08:04 PM']Hi all,
[snapback]183111[/snapback]
[/quote]
Thanks for the info! I'll see if I can get in touch with Koni and ask if those shocks only work with stock springs.
Old Oct 12, 2005 | 09:20 PM
ipse dixit's Avatar
Check with Ground Control.
While there isn't something off-the-shelf for the E60, I'm pretty sure they can customize a shock/strut setup for your needs.
Phone: 530-677-8600
Info: donfeen@ground-control.com
Support: support@ground-control.com
Old Oct 12, 2005 | 10:36 PM
soc_fans's Avatar
Phone:? 530-677-8600
Info:? ? ? ? ? ? donfeen@ground-control.com
Support:? ? ? ? support@ground-control.com
[snapback]183585[/snapback]
Yeah ground control made really good quality coilovers.
Old Oct 12, 2005 | 11:47 PM
heezy545i's Avatar
I was emailing a vendor and he informed me that ground control does not currently have a coilover setup for the e60. Still, they should be able to put a spring and shock combo together for you.
I know you're not interested in coilovers, but TC Kline offers a package with top adjustable konis and vogtland springs. That would be my suggestion if you're willing to spend the money.
BTW, did you ever get those rims fixed?
Old Oct 13, 2005 | 09:43 AM
ddkk's Avatar
I was told by the dealer (Budd's Hamilton, ON) that the H & R springs will work with the stock shocks (non-sport) without problem. Is there a reason you feel that you need to change the shocks?
Old Oct 13, 2005 | 02:40 PM
alpineweiss's Avatar
My Ride: 09 E90 M3
Originally Posted by ddkk' date='Oct 13 2005, 01:43 PM
I was told by the dealer (Budd's Hamilton, ON) that the H & R springs will work with the stock shocks (non-sport) without problem.? Is there a reason you feel that you need to change the shocks?
[snapback]183773[/snapback]
The stock shocks will wear down much quicker with the shorter aftermarket springs.
Bilstein should have shocks for the E60.
Old Oct 14, 2005 | 12:10 AM
6spdMan's Avatar
Originally Posted by choi000' date='Oct 12 2005, 09:04 AM
Hi all,
All I can say is that my H&R Coilovers rock!
Old Oct 14, 2005 | 12:21 AM
soc_fans's Avatar
Originally Posted by 6spdMan' date='Oct 14 2005, 03:10 AM
[quote name='choi000' date='Oct 12 2005, 09:04 AM']Hi all,
[snapback]184078[/snapback]
[/quote]
Do you know that H&R coilover will start to rust after being used for about 30,000 miles?
