SAT NAV RETROFIT advice needed for 2006 E61
My Ride: 2006 Audi A8 4.2TDI
Previous rides:
2005 E61 530d, 20" Breyton reps, Eibach springs, M5 bumper/mirrors/MFSW
2000 Audi S6 Avant, 18" OZ, RS6 exhaust etc
1998 Audi A8 4,2Q, 19" RS4 wheels, Remus exhaust KW coilovers etc
1986 Audi 100CC, funky fresh steel rims w plastic covers, rubber lip on boot.....
1987 BMW 320i, 15" alloys + rubber lip on boot :)
1982 Opel Ascona 1,6DL, tinted windows and a big-ass subwoofer :P
Depends on what unit you're aiming for. I installed business nav last weekend and it's quite simple. Just replace the DVD unit, add an antenna, get some programming at BMW and you're done. Haven't done the programming yet but I'll have it done in a few weeks. DVD unit cost me 120 bucks on ebay, antenna + extension cable was another 60 bucks and quote for programming is ~300 but then I'll have some more functions coded at the same time like mp3/ipod & bluetooth.
If you're going for pro nav it's a different story and you'll need to relace a bunch of other stuff. Use search function for more info.
About the antenna, you should have a receiver in your shark fin but the problem there is that you need a cable from the shark fin to your DVD, which means you basically need to tear down the roof liner. I went for a more simple solution recommended by Vesil here on the forum so I got an antenna from an E39 which I placed where the center speaker normally goes. Much easier, totally stealth and nothing that blocks it. For more info on this, look for Vesil's thread.
Originally Posted by wokingBigBoy' post='951977' date='Jul 23 2009, 05:22 PM
Does anyone have a model number for the SAT NAV DVD UNIT?
Try realoem.com for the part number.
Originally Posted by wokingBigBoy' post='967335' date='Aug 6 2009, 08:11 AM
Will a profesional dvd/sat nav unit work with the smallier monitor or do you have to have the widescreen monitor? THanks
Hi Big boy,
You can use the wiring loom from CCC to Monitor. Except you may find that the termination at the monitor to be the other way round. So use a penknife to shave off the plastic guide and it will fit.
However, the screen is 8.8inch and thus when I plug the screen to my orginal NON_NAV audio cd player, the other part of the screen came out blank.
Idrive controller for yours should be the NON-feedback low controller. it will continue working until the Pro-NAV CCC is inserted. Then you will need to change out the controller with the HIGH version which will feedback stuffs to you when you scroll it.
If you want to buy it off ebay, ask the seller to turn the knob and it should be free spinning. There will not be any clicking sounds when you turn the controller if its not plugged in. Then you will know its a HIGH controller for Pro-NAV use.
My car is not prewired. And thus there is no Blue GPS aerial antenna hanging in the dash... I am sourcing for the cable now. Everything is else is working fine.
Enjoy!!!
Enjoy!!!
I'd really like to know more about what you did?
In order to get the DVD player to interface with the iDrive and the screen what type of tear down was required? Did you have to pull apart a lot of the dashboard?
What's the difference with business and pro NAV...I don't even think we have business NAV in North America?
Do you have the small or widescreen display in your car?
Thanks in advance...
I have all the parts now, going to fit it in soon. The unit I have got is out a 2005 car mine is 2006. I have heard I just have to plug everything in and it will be fine without programming; is this true?
Got a quote to fit it in and it was ?1500 so im going to give it a crack myself :-)
