RPI Exhaust -- making weird noise
My Ride: Black Sapphire
2004 5.30i
I installed my exhaust a few weeks ago -- just clamp and go
Just recently I noticed an odd ...whining noise around 2000-2500 RPM -- kinda sounds like the noise a bad belt would make, but it is most definitley coming from the exhaust.
has anyone experienced this? or know what it is?
I've read where there is a whine created by air flow, and i hear that too -- this most certainly sounds different
2004 5.30i
I had to change my exhaust hangers last night because I was drooping a little.
While I was under there I looked for any leaks. I think my problem is coming from the clamp. It's on there as tight as I can get it...but it just won't sit flush between the 2 pipes. I'm pretty positive this is where my problem is coming from -- I think part of it may be because the there is some play right where the exhaust is clamped on (in the installation pictures there is the 3rd hanger right there but mine doens't have a 3rd hanger) -- anyone got a suggestion on how to troubleshoot this without having to weld?
Why not take some pics and contact either Eloy (RPIpower) or Joe (trinityautosport) they can probably help you figure it out and they both have great customer service. Good luck
If the exhaust doesn't sit properly and there's some give like you say, the stock exhaust piping was probably cut crooked. Remove the clamp, take some pictures and post them asap.
2004 5.30i
if the pipe not being cut 100% straight across can cause a problem than that is 100% it -- i'll try to find time to get some pictures, but i the pipe was not cut across evenly
that might be the problem you are having with leaks. did you cut the exhaust yourself? if so did you use masking tape to mark your line? be careful cutting the stock piping, if you cut it too short, your tips will be too far inwards.
