RPI Dyno Day Results, RPI M5 stage II & RPI M3
RPI DYNO DAY RESULTS
'08 535i JB3, RPI Scoop, Dinan Exhaust @ 310 WHP or 402.6 Crank
Richards M5 base dyno @ 388 WHP or 503.9 Crank
M3 w/AAA custom exhaust @ 302 WHP or 392.2 Crank
M3 w/RPI section 3 with AFI scoops @ 314 WHP or 407.8 Crank
Please be sure to post your dyno sheets when you can. Thanks!
I'm in the process of uploading the videos of the RPI M5 stage II and the M3 w/RPI GT Exhaust.
THey will be posted as soon as they are done uploading.
Originally Posted by Aviator' post='804129' date='Feb 28 2009, 03:05 PM
Damn 310 whp for your 535!!? That's sick!
Is there a chip/software for the 545 to get it close to those #'s???
![Worthy](https://5series.net/forums/images/smilies/imported/worthy.gif)
With a power chip reflash you should be putting up some decent numbers.
Originally Posted by MacFly?' post='804198' date='Feb 28 2009, 05:29 PM
D - strong numbers, congrats! how much torque were you pushin' out?
Originally Posted by dbae1978' post='804179' date='Feb 28 2009, 04:53 PM
I think if you get the RPI scoops and the new, soon to be released, RPI exahuast you should gain approxmatley 30-35 hp.
D- how many pulls did you do? Did you do a pull on the dyno with stock map, map 0 on the jb3? What map and octane were you running when you hit 310 hp?
***heard dynce's car was too low to get up the ramp to dyno....
Originally Posted by GENEaTALS' post='804280' date='Feb 28 2009, 10:20 PM
D- how many pulls did you do? Did you do a pull on the dyno with stock map? What map were you running when you hit 310 hp, map and octane?
